Has anyone added a Horstmann c- stat 17-zw to ST yet?
I’ve tried a number of handlers inc the 321thermostat and I can’t get it fully working.
I can sometimes get a device to appear in ST but no temperatures or set points are reported or controlled.
Thank you.
RBoy
2
It should work it has support for the command classes
Supported Command Classes
Association
Basic
Battery
Configuration
Manufacturer Specific
Multilevel Sensor
Schedule V1
Switch Binary
Thermostat Operating State
Thermostat Setpoint V2
Version
Wake Up
Controlled Command Classes
Basic
Thermostat Mode
Time
When using the stock ST device handler, what do you see in the logs?
Do you know which handler I should be using? The “Zwave Thermostat”?
Nothing appears in the logs unfortunately. I see the ST commands being sent, but nothing returned from polls or configures.
I’ve tried the handler that works on my SRT321s, and most with a thermostat in the name. Don’t know what I’m doing wrong.
Remove device by general exclusion. Reboot ST. Reset thermostat.
Add device, ‘stat to learn. ‘Stat recieves network data. ST defaults to the 321handler I have installed for other devices. Then nothing updates.
Tried again tonight, will leave it overnight and hope.
Thank you so far.
RBoy
4
Correct Z-Wave Thermostat should be work. You should see atleast something in the logs starting with
Parse returned
If you aren’t seeing that then the thermostat hasn’t paired properly. Try these steps (exactly) and then see if it works:
I was hoping the new firmware (18.18) would help, but i’m still struggling to get this Cstat working.
It adds fine, and after a bit of playing with he z-wave tweaker i think i understand the problem - it’s the wake up interval that’s currently set for 24hrs. Hence it’s not picking up any changes i make in the app, and rooms temperatures are inaccurate.
Is there a way to set the wake up interval to 900s?
All the device handlers i’ve tried don’t update it if there is a field for setting it. Wave Tweaker doesn’t have that field either. The device parameters doesn’t have it, so i can’t push it through.
Is there a code or anything i can use to set the interval to 900s, not 24hrs.
Hi Tom, did you every figure this one out? Were you just using the C-Stat 17w or the receiver HRT4-ASR-ZW as well? I can get it to connect and set temp but it seems to disconnect the ASR so the boiler goes into safety shutdown as it hasn’t received a signal from the thermostat. I saw on other forums that although these are Zwave they are only designed to communicate with each other not integrate into a system.
No, I never got it working myself.
It wasn’t connected directly to a boiler device as such, but it was associated to other on/off devices. These worked fine and with a Vera controller, just that the SetPoint wasn’t changeable by smartthings.
I’ve found the same. I can have them either (a) communicate with each other, or (b) see the thermostat in smartthings .
when it’s (b), turning the dial shows changes in real time in smartthings, but has absolutely no effect on the ASR, so regardless of what the temp says, the boiler won’t fire.
