Create lighting automations with Smart Lights
Hello,
where can I find my created light automation?.i get feedback that this was created but do not find it afterwards
In the SmartThings mobile App, under the “Automation” / SmartApps section.
Scroll down to “Smart Lighting”. Tap.
Thank you I have found it how I can test the one created automation
I’m not sure I know what you mean by “test”?
SmartThings doesn’t have a debugger. So if you have used Smart Lighting, just trigger the real-world condition(s) in the real-world and see if the actions occur in the real-world.
You can get some diagnostics in the Live Logging tab of https://account.smartthings.com
What is your automation supposed to do?
Ok Sorry for my poor english.
I mean,if I have created an automation and this starts only at 2 o’clock at night.
how can I check this before so I do not have to stay up until 2 o’clock at night?
in a routine I find no way to dim the light and change the color tone is that correct?
  • To test, just temporarily change the automation start time to a few minutes from “now” (e.g., 5pm instead of 2am). If it works at 5pm, then set the time to 2am and it will work properly then.
  • I don’t know all the limits or powers of Routines. There are more options in Smart Lighting. You can have a Routine turn on a Switch, and the Switch can be used as a trigger in Smart Lighting to do more.
  • There are many better SmartApps with more control. One of the easy ones with a lot of flexibility (but as an iOS App only, is “Smart Rules” in the Apple Store.
  • For lighting control, search the forum for “Trend Setter”.
  • The most popular powerful “rules engine” solution is webCoRE. https://community.webcore.co/
In other words … explore, explore, explore.
Thank you so you have helped me very much. I will make. Explorexploreexplore; -9
