Right, this should be a simple operation but can’t seem to create a piston to do what I want. What I am trying to achieve is to initiate a media notification on my sonos to notify that there has been a knock at the front door. I have used the Door Knocker smartapp however it is only limited to push notification or text message. Can anyone provide any guidance? I have trawled through the forum and can’t find anything in relation to doing this with Core.
Thanks for your response.
Do you not find though with this logic that the actions are initiated when the door is opened or closed, resulting from falsely triggering the acceleration sensor?
Well I think I’ve solved it. The following works for me. May be of some help for other people.
Did this work for you? I’m trying to achieve something very similar, only I’d like to use a bell as the notification through the sonos
Yes, works for me.
