Is there a way to change or a smart app for the SmartThings door sensor… That would let me change the acceleration sensitivity or delay for when i close the door… i have it set to notify me when the door opens, closes or if there is a knock on it, but when the door close a little to hard it say THERE IS A KNOCK AT THE DOOR instead of DOOR CLOSED…
The smart app I’m using for this is the
Sonos Smart App: Speaker Notify With Sound…
I use the “door knocker” smart app, it can be found in the smartapps marketplace under “more”. It won’t notify you when the contact is open/closed but it works well for detecting a knock. You could also achieve all of this with a core piston but that’s opening a whole new can of worms.
