Control4 Integration?
Hi,
We have a customer with a Control4 installation and he would like to control some zig-bee devices.
Is this possible using the hub?
Thanks,
Javier
Ip4home LLC
Talk to @pstuart, he has Control 4 and a working connection to SmartThings.
yes and no. Why not just use the already available integration with Wink? Do you want the devices to be reproduced in control4 and use SmartThings as a proxy? Or does the client want to use SmartThings side by side with Control4?
Anyway, send me a PM and we can discuss.
I did not know about Wink and I will check.
The customer want the devices to be reproduced in C4 and use Smarthings as proxy.
Thanks for your advice
Best Regards,
Javier Lopez
Ip4home LLC
Hi Patrick, @pstuart
I have a client that wants to integrate control4 devices with smarthings,
and if possible vice versa. They are on an old H-300 but they don’t have
anything bust lights and thermostats, and motions sensors, so the system
could definitely handle a driver implementation with smartthings. I’m new to the forum so
I don’t have the ability to private message.
Thanks,
Ryan Weller
ryanpaulweller@gmail.com
If you’re not replying directly to one of his posts, you can tag @pstuart with his username to make sure he sees your post. :sunglasses:
Thank you @JDRoberts
