I’m still not sure what the question is? The SmartSense Open/Close uses 2 part system in which a magnet determines contact or not. For example, the sensor would be mounted on the door frame and the included magnet would be mounted on the door. When the magnet is within a short distance (a few mm) then the contact is closed, anything else is considered open.
Aahhhh I see. I read contact closure as “contact enclosure” We’ve been getting all of our enclosures finished for production and its been stuck in my head. I can’t seem to find the example right now, but I have seen plenty of Z-Wave products you could use.
I recently wired this Z-Wave relay up to a garage door to control it via SmartThings. While that may be overkill, a simple contact closure is absolutely possible. Unfortunately at this point we don’t have any plans to manufacture our own off-the-shelf version. That’s not to say we wont be compatible with Z-wave or ZigBee HA modules.
Once the ThingShield and ThingModule are released, you very well could hack up your own. You could also use your idea of simply shorting our open/close sensor, but that may void your warranty I agree that the battery would not be sufficient for driving circuits, but the SmartSense Motion has an option for micro-USB power that you could hack into.
pmsmaker, if you find something please let me know. I am looking for something similar or may have to resort to making my own. I have seen some Zigbee devices available from doing some searches that are from China but there are no pictures available or specs and they require a minimum order. I don’t want to go to the hassle of building my own right now. I saw where Andrew Urman wired the Zwave module but it is overkill for what I need (garage door opener).
I found this today. It’s still a little overkill on the price. The biggest thing to consider how you’re going to power it. Closing a switch by a battery powered device wouldn’t be ideal.
Still going to think about it for a bit. It’s an interesting problem because with a relay connected to it and its closed, then the power to the manual button is cut off.
Here is a kit - Z-Wave Switch $52.27 & Contact $42.09 http://store.homeseer.com/store/Z-Wave-Garage-Door-Kit-P1281.aspx
Bear in mind these may or may not work with the Hub - but anyway they are specific to your App.
I would expect StartThings to do a ‘validation’ on these devices as they do have a niche for their market.
We’re working on the 3rd-party tested and approved list right now. I want to say Z-Wave compatibility is high across the board. Unless the device needs a specific z-wave stack enabled on our hub, then we add it to the stack. Could be added via OTA update down the road as well. I’ve used the LFM-20 relay from that kit you linked with our Hub and a nice assortment of different buttons/switches.
The garage door kit doesn’t tie into already existing wires and you replace the existing button with another Z-Wave button device. I brought up this thread in the office yesterday thought if someone could come up with a very small, simple, inexpensive Z-Wave or ZigBee garage door controller, it would make a fantastic entry into our big maker contest.
