Will check it out. Need to recreate a virtual mood switch.
met vriendelijke groeten,
Martin
Martin
just a small test, could you rename (in domoticz) to Kitchen Mood Switch? and hit refresh in SmartThings on the created device.
Interesting⌠There are now mood buttons, but the status is Off when it should be Group Mood 4, even after a refresh
could you hit mood 4 in smartthings and see what happens?
Seems to be working! Status in domoticz is now in sync with the app
The only way of really knowing i am dealing with a mood switch is to check for MOOD SWITCH to be present in the name and hardware being lightwaverfâŚwill change logic to check for MOOD only but it seems a bit too wide check. Have fun!
Thanks! Iâll change the name of the other mood switches. Iâm about to set up some rules in webcore. When I add devices, do I need to select all of the mood switch actuators? There seems to be one for each button
Guess so, but not a user of core myself. But all buttons are separate devices.
Got it working. Thanks so much, I now have use of all 6 buttons!
i donât know whatâs going on, but all of my selector switches are not working now.
tried removing and re-added those devices, doesnât help.
Anything updated in domoticz? Could you check the live logging in the ide for domoticz server app and device?
not sure about updates, using domoticz stable 4.9700
what i saw from live logging in the ide
domoticz server
5:39:23 PM: info childs : 43 5:39:23 PM: info state size : 40 5:39:23 PM: debug getChildDevices(false), children=43 5:39:23 PM: info Delete from State devices [] 5:39:23 PM: info Deleted, remove child devices [] 5:39:23 PM: info New in Domoticz[]
all others devices in question showing only
5:44:20 PM: info [updateChildren]
seems like all my selector switches failed getting child devices. showing only NULL or some alphanumeric value in the mobile app. (iâll update with mobile app screenshot)
Will run a test later todayâŚ
something has changed in DOmoticz, the content of field level actions has changedâŚto something not very meaningfulâŚ
LevelNames are being encoded in the latest stable if Domoticz, i have changed code to decode. Update to 7.12 should fix the issue.
updated. everythingâs back to normal
thanks
@dudz40 hey martin, still working hard on the code I see
Everything is working great for me still but as ST have their numerous outages iâm finding myself moving devices around to local processing where I can.
In relation to this integration I assume this is deemed cloud based as
Domoticz is local
Handler is cloud
ST Hub is local
Just looking into my options
Thanks and keep up the great work.
Iâm finding that my mood switches are being triggered in the middle of the night but not sure why:
2018-09-04 5:24:13.412 AM BST
2018-09-04 5:24:13.387 AM BST
Nothing in the domoticz events log for the same device:
Any ideas?
sorry, was away for a while. Still experiencing this?
No problem.
Yes still happening, no idea why though!
