According to Domoticz device list = 569, I don’t use them all but on the tabs about 150, some of them being combined like TH + RH
The error only happens when the initial child devices (capabilities) are added, modified code to test for it. The error is not related to the problem in domoticz.
are you seeing these types of messages if you leave logging running for a while, especially the [eventDomoticz] ones, this is where the notification messages from Domoticz come in…
One other thing to try is the following, copy the Url/Action from HTTP notification in domoticz into address of a browser and hit enter, it is OK if it does return a blank screen, otherwise i am interested in the info that comes back.
Tried the link but outside my home (at work now) and returned this:
{"error":true,"type":"AccessDenied","message":"This request is not authorized by the specified access token"}
I guess I need to be on the same LAN
No need to be on the same lan. Could you go to the smart app and do revoke access token? It will get you a new one. Save, to be sure and copy paste the newly created customactionurl into domoticz.
Done, all seems to work now. I still seem to have the odd error on Domoticz log, like:
2018-06-27 22:02:16.033 EnOcean: 01 (0A/07) A5 73 4F 76 0E 05 03 D5 8E 00 01 FF FF FF FF 56 00
2018-06-27 22:02:16.033 EnOcean: destination: 0xffffffff RSSI: 14
2018-06-27 22:02:16.033 EnOcean: 4BS data: Sender id: 0x0503d58e Status: 00 Data: 76
2018-06-27 22:02:16.039 Notification: SENSOR 935 Temp 23.6
2018-06-27 22:02:16.041 (EnOcean-USB) Temp + Humidity (TH / RH Co2)
2018-06-27 22:02:16.061 Notification: SENSOR 936 AirQuality 790
2018-06-27 22:02:16.062 (EnOcean-USB) Air Quality (Co2)
2018-06-27 22:02:16.136 Error: HTTP:
2018-06-27 22:02:16.136 Notification sent (http) => Failed
2018-06-27 22:02:16.239 Error: HTTP:
2018-06-27 22:02:16.239 Notification sent (http) => Failed
this is a triple sensor, I have created a composite one with it, TH and RH are ok but CO2 shows = 0 on the ST App. The error seems to happen on the composite sensors.
Honestly, no need to solve this for me, you have been very helpful, so feel free to ignore me. I’m happy as it is, and it is a lot more than I had 2 days ago!
Out of curiosity, when I trigger a switch on Domoticz, how long would I have to wait to see it on the App? Domoticz to ST does not seem to refresh automatically until I force a refresh on the App.
However the other way around works, ST to Domoticz refreshes ok.
Should be pretty quick, the notification will result in an event in ST, but sometimes the ST cloud is busy
Not aware that I did co2, will do some checking.
More than happy to keep providing feedback if it helps you make even better the plugin
I have quite a hybrid system, for example I can see some thermostats also showing part of the information (I have Evohome and Z-wave TRVs combines).
Then I use wired contact switches for my doors and these are displayed on the app as very smart devices with battery, temperature, etc… I guess is in reference to the original ST sensors.
More than happy to provide feedback if it helps, for my I’m happy as it is now.
Please do, always looking for suggestions etc…
The CO2 is Airquality sensors? if so could you paste the output of
domoticzIP/json.htm?type=devices&rid=your sensor idx
More than happy to do so!
"ActTime" : 1530177355,
"AstrTwilightEnd" : "00:00",
"AstrTwilightStart" : "00:00",
"CivTwilightEnd" : "23:05",
"CivTwilightStart" : "03:38",
"DayLength" : "17:28",
"NautTwilightEnd" : "00:00",
"NautTwilightStart" : "00:00",
"ServerTime" : "2018-06-28 10:15:55",
"SunAtSouth" : "13:05",
"Sunrise" : "04:38",
"Sunset" : "22:06",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "1050 ppm",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 13,
"HardwareName" : "EnOcean-USB",
"HardwareType" : "EnOcean USB (ESP3)",
"HardwareTypeVal" : 31,
"HaveTimeout" : false,
"ID" : "0003",
"LastUpdate" : "2018-06-28 10:11:55",
"Name" : "Co2",
"Notifications" : "true",
"PlanID" : "12",
"PlanIDs" : [ 12 ],
"Protected" : false,
"Quality" : "Fair",
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "Voltcraft CO-20",
"Timers" : "false",
"Type" : "Air Quality",
"TypeImg" : "air",
"Unit" : 213,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "936"
"status" : "OK",
"title" : "Devices"
Thanks, this is what I expect, need to look into code why it is not updating automatically.
met vriendelijke groeten,
Martin
Actually it is updating correctly in my setup…could you check for events at the follwoing place? go to the composite sensor in ide under devices and click on the child device for AirQuailty to see it’s events, if all is good they should show…
Has anyone tried to use blinds from domoticz in alexa, for some reason if you tell alexa to open the blinds it closes the blinds and if you tell it to close the blinds it opens them, has anyone found a solution to this ?
Thought there always was an issue with open and close support by Alexa? Is that no longer an issue?
Martin
no clue, i would have thought you could change domotics to map on and off differently maybe ?
Yes it is there, I can see air quality option, it just shows zero value
are you looking here under devices, select your main composite device:
click on the air quality device,you see something like this:
if you then click on Airquality, evry curious what you see now:
Hi, finally found some time to try and get my mood switches working. With the latest DTH and Smartapp it looks like the mood switches are recognised. The one I have set to mood now has a LWRF logo, and it changes to the button name that is pressed - great work!
I noticed in the live log I’m getting a few errors, any idea what these are?
