Could you PM me the application state. You find it under ide my locations , installed apps, domoticz server. I am interested in the contents of the settings and the state variables. This way I can follow logic. I have no real ability to start from scratch with all the used devices😑
suddenly I found all the domoticz scenes pop up in my phone’s app. But they all have off line status in the IDE and “This device is unavailable” message appear in the device screen of the phone smartthing app. I captured the log with error message attached.
scene devices are added, but looks like the corresponding item in application state is not there…really need the content of the app settings and state…
I have committed 7.11 of the app. I found two problems, one is related to the above null pointer. The other is that i rewrote the function that is handling the request for all devices from domoticz, i noticed that i do not check for a state that nothing exists…might be the cause (not sure…)
I could not find any update from your repo. I have been stuck with domoticz server since then. Now imy IDE and iOS app ound all the domoticz scenes again but in uneachable status and not working.
Hi Minh, it is weird. Could you do me a favour and check and remove all instances of domoticz server app via the ide? Go to my locations, list smartaps, in the top click edit, then you can easily remove any occurrence.
Then do a fresh install of the app, and reply step by step how you configure it. I hope to find the missing link that way, sorry for the trouble.
Yes, actionUrl + whitelist + OAuth enabled smartApp.
I’ll have further play… hopefully is not the amount of devices I have (about 300 or so) that is causing the issue.
Should not be a problem with 300 devices, notification should only be send when things change, do you see any notification success messages.
I see a failed for a switch type as well in your log.
Could you try one thing, a problem I had before is that when I pasted the customurl it had an extra character at the end that I could not see, could you redo the customurl?
You can check for invalid url as well in the app, it will show invalid url message in the configure screen.
For some types i will retrueve status another way as well. It is urlcustomactionhttp. Just go into the app and see if it indicates valid url in domoticz ? Should say true
Using the latest stable myself. Could you go to the smartthings ide and display loggjng for domoticz server. Before check if trace is enabled in the app. There must be entries showing for domoticzevent…
