Connecting with POPP Door and Window Sensor POPE700892
Hello,
I have the opportunity to buy a POPP Door and Window Sensor POPE700892 from the secondary market. The sensor works on Z-Wave. There is no information about whether it is compatible with ST. Do you think it will be possible to connect it as a Z-Wave Generic Device?
First rule of home automation: “the model number matters.“
For example, some popp door sensors also act as a tilt sensor.
Also, you have to make sure that the way frequency exactly matches the frequency of your hub. you need to check to be sure, just in case it’s a model that was from a different region.
If it is the same frequency, you can definitely connect it as a generic device, but how useful that will be again depends on the model. :thinking:
I’m a little bit concerned because the door sensor is not one of the popp devices listed as compatible on the smartthings site:
https://www.smartthings.com/partners/popp
Finally I connect this device with my ST hub with succes. It works very good. I also receive last device handler form device manufacturer with permission to publish here.
 *  Copyright 2015 SmartThings
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 *  Z-Wave Door/Window Sensor
 *  Author: SmartThings
 *  Date: 2013-11-3
metadata {
	definition(name: "Z-Wave Door/Window Sensor", namespace: "smartthings", author: "SmartThings", ocfDeviceType: "x.com.st.d.sensor.contact", runLocally: true, minHubCoreVersion: '000.017.0012', executeCommandsLocally: false, genericHandler: "Z-Wave") {
		capability "Contact Sensor"
		capability "Sensor"
		capability "Battery"
		capability "Configuration"
		capability "Health Check"
		capability "Tamper Alert"
		fingerprint deviceId: "0x2001", inClusters: "0x30,0x80,0x84,0x85,0x86,0x72", deviceJoinName: "Open/Closed Sensor"
		fingerprint deviceId: "0x07", inClusters: "0x30", deviceJoinName: "Open/Closed Sensor"
		fingerprint deviceId: "0x0701", inClusters: "0x5E,0x98", deviceJoinName: "Open/Closed Sensor"
		fingerprint deviceId: "0x0701", inClusters: "0x5E,0x86,0x72,0x98", outClusters: "0x5A,0x82", deviceJoinName: "Open/Closed Sensor"
		fingerprint deviceId: "0x0701", inClusters: "0x5E,0x80,0x71,0x85,0x70,0x72,0x86,0x30,0x31,0x84,0x59,0x73,0x5A,0x8F,0x98,0x7A", outClusters: "0x20", deviceJoinName: "Open/Closed Sensor"
		// Philio multi+
		fingerprint mfr: "0086", prod: "0002", model: "001D", deviceJoinName: "Aeotec Open/Closed Sensor" //Aeotec Door/Window Sensor (Gen 5)
		fingerprint mfr: "0086", prod: "0102", model: "0070", deviceJoinName: "Aeotec Open/Closed Sensor" //US //Aeotec Door/Window Sensor 6
		fingerprint mfr: "0086", prod: "0002", model: "0070", deviceJoinName: "Aeotec Open/Closed Sensor" //EU //Aeotec Door/Window Sensor 6
		fingerprint mfr: "0086", prod: "0202", model: "0070", deviceJoinName: "Aeotec Open/Closed Sensor" //AU //Aeotec Door/Window Sensor 6
		fingerprint mfr: "0086", prod: "0102", model: "0059", deviceJoinName: "Aeotec Open/Closed Sensor" //Aeotec Recessed Door Sensor
		fingerprint mfr: "014A", prod: "0001", model: "0002", deviceJoinName: "Ecolink Open/Closed Sensor" //Ecolink Door/Window Sensor
		fingerprint mfr: "014A", prod: "0001", model: "0003", deviceJoinName: "Ecolink Open/Closed Sensor" //Ecolink Tilt Sensor
		fingerprint mfr: "014A", prod: "0004", model: "0003", deviceJoinName: "Ecolink Open/Closed Sensor" //Ecolink Tilt Sensor
		fingerprint mfr: "011A", prod: "0601", model: "0903", deviceJoinName: "Enerwave Open/Closed Sensor" //Enerwave Magnetic Door/Window Sensor
		fingerprint mfr: "014F", prod: "2001", model: "0102", deviceJoinName: "Nortek Open/Closed Sensor" //Nortek GoControl Door/Window Sensor
		fingerprint mfr: "0063", prod: "4953", model: "3031", deviceJoinName: "Jasco Open/Closed Sensor" //Jasco Hinge Pin Door Sensor
		fingerprint mfr: "019A", prod: "0003", model: "0003", deviceJoinName: "Sensative Open/Closed Sensor" //Sensative Strips
		fingerprint mfr: "0258", prod: "0003", model: "0082", deviceJoinName: "NEO Coolcam Open/Closed Sensor" //NEO Coolcam Door/Window Sensor
		fingerprint mfr: "0258", prod: "0003", model: "1082", deviceJoinName: "NEO Coolcam Open/Closed Sensor" // NAS-DS01ZE //NEO Coolcam Door/Window Sensor
		fingerprint mfr: "021F", prod: "0003", model: "0101", deviceJoinName: "Dome Open/Closed Sensor" //Dome Door/Window Sensor
		//zw:S type:0701 mfr:014A prod:0004 model:0002 ver:10.01 zwv:4.05 lib:06 cc:5E,86,72,73,80,71,85,59,84,30,70 ccOut:20 role:06 ff:8C07 ui:8C00
		fingerprint mfr: "014A", prod: "0004", model: "0002", deviceJoinName: "Ecolink Open/Closed Sensor" //Ecolink Door/Window Sensor
		//zw:Ss type:0701 mfr:0086 prod:0002 model:0059 ver:1.14 zwv:3.92 lib:03 cc:5E,86,72,98,5A ccOut:82 sec:30,80,84,70,85,59,71,7A,73 role:06 ff:8C00 ui:8C00
		fingerprint mfr: "0086", prod: "0002", model: "0059", deviceJoinName: "Aeon Open/Closed Sensor" //Aeon Recessed Door Sensor
		//zw:S type:0701 mfr:0214 prod:0002 model:0001 ver:6.38 zwv:4.38 lib:06 cc:5E,30,84,80,86,72,71,70,85,59,73,5A role:06 ff:8C06 ui:8C06
		fingerprint mfr: "0214", prod: "0002", model: "0001", deviceJoinName: "BeSense Open/Closed Sensor" //BeSense Door/Window Detector
		fingerprint mfr: "0086", prod: "0002", model: "0078", deviceJoinName: "Aeotec Open/Closed Sensor" //EU //Aeotec Door/Window Sensor Gen5
		fingerprint mfr: "0371", prod: "0102", model: "0007", deviceJoinName: "Aeotec Open/Closed Sensor" //EU //Aeotec Door/Window Sensor 7
		fingerprint mfr: "0371", prod: "0002", model: "0007", deviceJoinName: "Aeotec Open/Closed Sensor" //US //Aeotec Door/Window Sensor 7
		fingerprint mfr: "0060", prod: "0002", model: "0003", deviceJoinName: "Everspring Open/Closed Sensor" //US & EU //Everspring Door/Window Sensor
		fingerprint mfr: "0371", prod: "0102", model: "00BB", deviceJoinName: "Aeotec Open/Closed Sensor" //US //Aeotec Recessed Door Sensor 7
		fingerprint mfr: "0371", prod: "0002", model: "00BB", deviceJoinName: "Aeotec Open/Closed Sensor" //EU //Aeotec Recessed Door Sensor 7
		fingerprint mfr: "0109", prod: "2022", model: "2201", deviceJoinName: "Vision Open/Closed Sensor" //AU //Vision Recessed Door Sensor
		fingerprint mfr: "0371", prod: "0002", model: "000C", deviceJoinName: "Aeotec Open/Closed Sensor", mnmn: "SmartThings", vid: "generic-contact-5" //EU //Aeotec Door/Window Sensor 7 Pro
		fingerprint mfr: "0371", prod: "0102", model: "000C", deviceJoinName: "Aeotec Open/Closed Sensor", mnmn: "SmartThings", vid: "generic-contact-5" //US //Aeotec Door/Window Sensor 7 Pro
		fingerprint mfr: "0371", prod: "0202", model: "000C", deviceJoinName: "Aeotec Open/Closed Sensor", mnmn: "SmartThings", vid: "generic-contact-5" //AU //Aeotec Door/Window Sensor 7 Pro
		fingerprint mfr: "0371", prod: "0002", model: "000B", deviceJoinName: "Aeotec Open/Closed Sensor", mnmn: "SmartThings", vid: "generic-contact-5" //EU //Aeotec Door/Window Sensor 7 zw:Ss2a type:0701 mfr:0371 prod:0002 model:000B ver:1.01 zwv:7.12 lib:03 cc:5E,55,9F,6C sec:86,85,8E,59,72,5A,87,73,80,70,71,84,7A
		fingerprint mfr: "0371", prod: "0102", model: "000B", deviceJoinName: "Aeotec Open/Closed Sensor", mnmn: "SmartThings", vid: "generic-contact-5" //US //Aeotec Door/Window Sensor 7 zw:Ss2a type:0701 mfr:0371 prod:0102 model:000B ver:1.01 zwv:7.12 lib:03 cc:5E,55,9F,6C sec:86,85,8E,59,72,5A,87,73,80,70,71,84,7A
		//zw:Ss2a type:0701 mfr:027A prod:7000 model:E001 ver:1.05 zwv:7.13 lib:03 cc:5E,55,9F,6C sec:86,85,8E,59,72,5A,87,73,80,71,30,70,84,7A
		fingerprint mfr: "027A", prod: "7000", model: "E001", deviceJoinName: "Zooz Open/Closed Sensor" //Zooz ZSE41 XS Open Close Sensor
		fingerprint mfr: "0154", prod: "0004", model: "0007", deviceJoinName: "POPP Open/Closed Sensor" //EU //POPP Door Window Sensor
	// simulator metadata
	simulator {
		// status messages
		status "open": "command: 2001, payload: FF"
		status "closed": "command: 2001, payload: 00"
		status "wake up": "command: 8407, payload: "
	// UI tile definitions
	tiles(scale: 2) {
		multiAttributeTile(name: "contact", type: "generic", width: 6, height: 4) {
			tileAttribute("device.contact", key: "PRIMARY_CONTROL") {
				attributeState("open", label: '${name}', icon: "st.contact.contact.open", backgroundColor: "#e86d13")
				attributeState("closed", label: '${name}', icon: "st.contact.contact.closed", backgroundColor: "#00A0DC")
		valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
			state "battery", label: '${currentValue}% battery', unit: ""
		main "contact"
		details(["contact", "battery"])
private getCommandClassVersions() {
	[0x20: 1, 0x25: 1, 0x30: 1, 0x31: 5, 0x80: 1, 0x84: 1, 0x71: 3, 0x9C: 1]
	def result = null
	if (description.startsWith("Err 106")) {
		if ((zwaveInfo.zw == null && state.sec != 0) || zwaveInfo?.zw?.contains("s")) {
			log.debug description
		} else {
			result = createEvent(
				descriptionText: "This sensor failed to complete the network security key exchange. If you are unable to control it via SmartThings, you must remove it from your network and add it again.",
				eventType: "ALERT",
				value: "failed",
				isStateChange: true,
	} else if (description != "updated") {
		def cmd = zwave.parse(description, commandClassVersions)
		if (cmd) {
			result = zwaveEvent(cmd)
	log.debug "parsed '$description' to $result"
	return result
def installed() {
	// Device-Watch simply pings if no device events received for 482min(checkInterval)
	sendEvent(name: "checkInterval", value: 2 * 4 * 60 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
	// this is the nuclear option because the device often goes to sleep before we can poll it
	sendEvent(name: "contact", value: "open", descriptionText: "$device.displayName is open")
	sendEvent(name: "battery", unit: "%", value: 100)
	sendEvent(name: "tamper", value: "clear")
	response(initialPoll())
def updated() {
def configure() {
	//Recessed Door Sensor 7 - Enable Binary Sensor Report for S2 Authenticated
	if (zwaveInfo.mfr == "0371" || zwaveInfo.model == "00BB") {
		result << response(command(zwave.configurationV1.configurationSet(parameterNumber: 1, size: 1, scaledConfigurationValue: 1)))
		result
def sensorValueEvent(value) {
	if (value) {
		createEvent(name: "contact", value: "open", descriptionText: "$device.displayName is open")
	} else {
		createEvent(name: "contact", value: "closed", descriptionText: "$device.displayName is closed")
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
	sensorValueEvent(cmd.value)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd) {
	sensorValueEvent(cmd.sensorValue)
def zwaveEvent(physicalgraph.zwave.commands.sensoralarmv1.SensorAlarmReport cmd) {
	sensorValueEvent(cmd.sensorState)
def zwaveEvent(physicalgraph.zwave.commands.notificationv3.NotificationReport cmd) {
	def result = []
	if (cmd.notificationType == 0x06 && cmd.event == 0x16) {
		result << sensorValueEvent(1)
	} else if (cmd.notificationType == 0x06 && cmd.event == 0x17) {
		result << sensorValueEvent(0)
	} else if (cmd.notificationType == 0x07) {
		if (cmd.v1AlarmType == 0x07) {  // special case for nonstandard messages from Monoprice door/window sensors
			result << sensorValueEvent(cmd.v1AlarmLevel)
		} else if (cmd.event == 0x00) {
			result << createEvent(name: "tamper", value: "clear")
		} else if (cmd.event == 0x01 || cmd.event == 0x02) {
		} else if (cmd.event == 0x03) {
			runIn(10, clearTamper, [overwrite: true, forceForLocallyExecuting: true])
			result << createEvent(name: "tamper", value: "detected", descriptionText: "$device.displayName was tampered")
			if (!state.MSR) result << response(command(zwave.manufacturerSpecificV2.manufacturerSpecificGet()))
		} else if (cmd.event == 0x05 || cmd.event == 0x06) {
			result << createEvent(descriptionText: "$device.displayName detected glass breakage", isStateChange: true)
		} else if (cmd.event == 0x07) {
			result << createEvent(name: "motion", value: "active", descriptionText: "$device.displayName detected motion")
	} else if (cmd.notificationType) {
		def text = "Notification $cmd.notificationType: event ${([cmd.event] + cmd.eventParameter).join(", ")}"
		result << createEvent(name: "notification$cmd.notificationType", value: "$cmd.event", descriptionText: text, displayed: false)
	} else {
		def value = cmd.v1AlarmLevel == 255 ? "active" : cmd.v1AlarmLevel ?: "inactive"
		result << createEvent(name: "alarm $cmd.v1AlarmType", value: value, displayed: false)
	result
def zwaveEvent(physicalgraph.zwave.commands.wakeupv1.WakeUpNotification cmd) {
	def event = createEvent(descriptionText: "${device.displayName} woke up", isStateChange: false)
	def cmds = []
	if (!state.MSR) {
		cmds << zwave.manufacturerSpecificV2.manufacturerSpecificGet()
	if (device.currentValue("contact") == null) {
		// In case our initial request didn't make it, initial state check no. 3
		cmds << zwave.sensorBinaryV2.sensorBinaryGet(sensorType: zwave.sensorBinaryV2.SENSOR_TYPE_DOOR_WINDOW)
	if (!state.lastbat || now() - state.lastbat > 53 * 60 * 60 * 1000) {
		cmds << zwave.batteryV1.batteryGet()
	def request = []
	if (cmds.size() > 0) {
		request = commands(cmds, 1000)
		request << "delay 20000"
	request << zwave.wakeUpV1.wakeUpNoMoreInformation().format()
	[event, response(request)]
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
	def map = [name: "battery", unit: "%"]
	if (cmd.batteryLevel == 0xFF) {
		map.value = 1
		map.descriptionText = "${device.displayName} has a low battery"
		map.isStateChange = true
	} else {
		map.value = cmd.batteryLevel
	state.lastbat = now()
	[createEvent(map)]
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
	def result = []
	def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
	log.debug "msr: $msr"
	updateDataValue("MSR", msr)
	result << createEvent(descriptionText: "$device.displayName MSR: $msr", isStateChange: false)
	// change DTH if required based on MSR
	if (!retypeBasedOnMSR()) {
		if (msr == "011A-0601-0901") {
			// Enerwave motion doesn't always get the associationSet that the hub sends on join
			result << response(zwave.associationV1.associationSet(groupingIdentifier: 1, nodeId: zwaveHubNodeId))
	} else {
		// if this is door/window sensor check initial contact state no.2
		if (!device.currentState("contact")) {
			result << response(command(zwave.sensorBinaryV2.sensorBinaryGet(sensorType: zwave.sensorBinaryV2.SENSOR_TYPE_DOOR_WINDOW)))
	// every battery device can miss initial battery check. check initial battery state no.2
	if (!device.currentState("battery")) {
		result << response(command(zwave.batteryV1.batteryGet()))
	result
def zwaveEvent(physicalgraph.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
	def encapsulatedCommand = cmd.encapsulatedCommand(commandClassVersions)
	if (encapsulatedCommand) {
		zwaveEvent(encapsulatedCommand)
def zwaveEvent(physicalgraph.zwave.commands.crc16encapv1.Crc16Encap cmd) {
	def version = commandClassVersions[cmd.commandClass as Integer]
	def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
	def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
		return zwaveEvent(encapsulatedCommand)
def zwaveEvent(physicalgraph.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
	def result = null
	if (cmd.commandClass == 0x6C && cmd.parameter.size >= 4) { // Supervision encapsulated Message
		// Supervision header is 4 bytes long, two bytes dropped here are the latter two bytes of the supervision header
		cmd.parameter = cmd.parameter.drop(2)
		// Updated Command Class/Command now with the remaining bytes
		cmd.commandClass = cmd.parameter[0]
		cmd.command = cmd.parameter[1]
	log.debug "Command from endpoint ${cmd.sourceEndPoint}: ${encapsulatedCommand}"
		result = zwaveEvent(encapsulatedCommand)
	result
def zwaveEvent(physicalgraph.zwave.commands.multicmdv1.MultiCmdEncap cmd) {
	log.debug "MultiCmd with $numberOfCommands inner commands"
	cmd.encapsulatedCommands(commandClassVersions).collect { encapsulatedCommand ->
	}.flatten()
	createEvent(descriptionText: "$device.displayName: $cmd", displayed: false)
def initialPoll() {
	def request = []
	if (isEnerwave()) { // Enerwave motion doesn't always get the associationSet that the hub sends on join
		request << zwave.associationV1.associationSet(groupingIdentifier: 1, nodeId: zwaveHubNodeId)
	// check initial battery and contact state no.1
	request << zwave.batteryV1.batteryGet()
	request << zwave.sensorBinaryV2.sensorBinaryGet(sensorType: zwave.sensorBinaryV2.SENSOR_TYPE_DOOR_WINDOW)
	request << zwave.manufacturerSpecificV2.manufacturerSpecificGet()
	commands(request, 500) + ["delay 6000", command(zwave.wakeUpV1.wakeUpNoMoreInformation())]
private command(physicalgraph.zwave.Command cmd) {
	if ((zwaveInfo?.zw == null && state.sec != 0) || zwaveInfo?.zw?.contains("s")) {
		zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
	} else {
		cmd.format()
private commands(commands, delay = 200) {
	delayBetween(commands.collect { command(it) }, delay)
def retypeBasedOnMSR() {
	def dthChanged = true
	switch (state.MSR) {
		case "0086-0002-002D":
			log.debug "Changing device type to Z-Wave Water Sensor"
			setDeviceType("Z-Wave Water Sensor")
			break
		case "011F-0001-0001":  // Schlage motion
		case "014A-0001-0001":  // Ecolink motion
		case "014A-0004-0001":  // Ecolink motion +
		case "0060-0001-0002":  // Everspring SP814
		case "0060-0001-0003":  // Everspring HSP02
		case "011A-0601-0901":  // Enerwave ZWN-BPC
			log.debug "Changing device type to Z-Wave Motion Sensor"
			setDeviceType("Z-Wave Motion Sensor")
			break
		case "013C-0002-000D":  // Philio multi +
			log.debug "Changing device type to 3-in-1 Multisensor Plus (SG)"
			setDeviceType("3-in-1 Multisensor Plus (SG)")
			break
		case "0109-2001-0106":  // Vision door/window
			log.debug "Changing device type to Z-Wave Plus Door/Window Sensor"
			setDeviceType("Z-Wave Plus Door/Window Sensor")
			break
		case "0109-2002-0205": // Vision Motion
			log.debug "Changing device type to Z-Wave Plus Motion/Temp Sensor"
			setDeviceType("Z-Wave Plus Motion/Temp Sensor")
			break
		default:
			dthChanged = false
			break
	dthChanged
// this is present in zwave-motion-sensor.groovy DTH too
private isEnerwave() {
	zwaveInfo?.mfr?.equals("011A") && zwaveInfo?.prod?.equals("0601") && zwaveInfo?.model?.equals("0901")
def clearTamper() {
