The Xbee s2c module that connected with uart serial port of my mcu and set Coordinator mode
received the data from open/closed smartsesnse through ZDO command.
the next step of simple description response is ZCL request to read a cluster attributes (app. version, manufacturer, model request etc.), following as below references, so coordinator sent End-point ZCL data.
But I could not receive ZCL attributes data because of ‘not found network’ error.
How do I configure ZCL packets using the endpoints and cluster values obtained in the process below?
Let me know if there is a process that needs to be added to form a network between Coordinator and End-device before using ZCL data.
(data logs from coordinator)
Rx << 7E | 001E | 91 00 0D 6F 00 04 05 5D 07 F8 38 00 00 00 13 00 00 02 D9 38 F8 07 5D 05 04 00 6F 0D 00 80 | CE
Explicit Rx Indicator
DestAddr64 : 000D6F0004055D07
DestAddr16 : F838
Src.EP : 00
Dst.EP : 00
ClusterId :0013
ProfileId :0000
RxOption : 02
Payload : D938F8075D0504006F0D0080
DEVICE ANNOUNCE FROM ENDDEVICE
FrameId : D9
NWKAddr : F838
IEEEAddr : 000D6F0004055D07
Capability : 80
Tx > 7E | 0017 | 11 DA 00 0D 6F 00 04 05 5D 07 F8 38 00 00 00 05 00 00 00 00 DA 38 F8 | EC
Explicit Addressing Command Frame
FrameId : DA
DestAddr16 : F838
Src.EP : 00
Dst.EP : 00
ClusterId :0005
ProfileId :0000
Broadcast Radius : 00
Option : 00
Payload : DA38F8
Rx << 7E | 0019 | 91 00 0D 6F 00 04 05 5D 07 F8 38 00 00 80 05 00 00 01 DA 00 38 F8 02 01 02 | C0
DestAddr16 : F838
Src.EP : 00
Dst.EP : 00
ClusterId :8005
ProfileId :0000
RxOption : 01
Payload : DA0038F8020102
ACTIVE ENDPOINT RESPONSE
FrameId : DA
Status : 00
NWKAddressOfInterest : F838
ActiveEPCount : 02
ActiveEPList : 0102
Tx > 7E | 0018 | 11 DA 00 0D 6F 00 04 05 5D 07 F8 38 00 00 00 04 00 00 00 00 DA 38 F8 01 | EC
FrameId : DA
DestAddr16 : F838
Src.EP : 00
Dst.EP : 00
ClusterId :0004
ProfileId :0000
Option : 00
Payload : DA38F801
Rx << 7E | 002F | 91 00 0D 6F 00 04 05 5D 07 F8 38 00 00 80 04 00 00 01 DA 00 38 F8 18 01 04 01 02 04 00 07 00 00 01 00 03 00 02 04 00 05 20 00 05 0B 01 19 00 | 42
DestAddr16 : F838
Src.EP : 00
Dst.EP : 00
ClusterId :8004
ProfileId :0000
RxOption : 01
Payload : DA0038F81801040102040007000001000300020400052000050B011900
SIMPLE DESCRIPTOR RESPONSE
FrameId : DA
Status : SUCCESS
NWKAddrOfInterest : F838
Length : 18
SimpleDescriptor
- Endpoint : 01
- Application profile identifier : 0104 - ZIGBEE HOME AUTOMATION
- Application device identifier : 0402 - IAS Zone
- Application device version : 00
- Application input cluster count : 07
- Application input cluster list : 0B05 0020 0500 0402 0003 0001 0000
- Application output cluster count : 01
- Application output cluster list : 0019
Tx > 7E | 0018 | 11 DA 00 0D 6F 00 04 05 5D 07 F8 38 00 00 00 04 00 00 00 00 DA 38 F8 02 | EB
FrameId : DA
DestAddr16 : F838
Src.EP : 00
Dst.EP : 00
ClusterId :0004
ProfileId :0000
Option : 00
Payload : DA38F802
Rx << 7E | 002B | 91 00 0D 6F 00 04 05 5D 07 F8 38 00 00 80 04 00 00 01 DA 00 38 F8 14 02 DF C2 0C 00 00 05 00 00 01 00 03 00 05 0B 0F FC 01 03 00 | DB
DestAddr16 : F838
Src.EP : 00
Dst.EP : 00
ClusterId :8004
ProfileId :0000
RxOption : 01
Payload : DA0038F81402DFC20C000005000001000300050B0FFC010300
FrameId : DA
Status : SUCCESS
Length : 14
SimpleDescriptor
- Endpoint : 02
- Application profile identifier : C2DF - Unknown device or Add Profile ID Info.
- Application device identifier : 000C - Simple Sensor
- Application input cluster count : 05
- Application input cluster list : FC0F 0B05 0003 0001 0000
- Application output cluster list : 0003
Tx > (zcl) 7E | 001B | 11 5D 00 0D 6F 00 04 05 5D 07 E0 3C 01 01 00 00 01 04 00 00 00 00 00 00 00 01 00 | 84
FrameId : 5D
DestAddr16 : E03C
Src.EP : 01
Dst.EP : 01
ClusterId :0000
ProfileId :0104
Option : 00
Payload : 00000000000100
Rx << 7E | 0007 | 8B E1 FF FD 00 24 02 | 71
Transmit Status : Access Not found / Route Discovery
(references)
- http://knowledge.digi.com/articles/Knowledge_Base_Article/Zigbee-Home-Automation
- https://github.com/MikeMaxwell/SmartThingsPublic/blob/master/devicetypes/smartthings/smartsense-open-closed-sensor.src/smartsense-open-closed-sensor.groovy
- Controle smartthings devices with xbee
- zigbee-cluster-library-specification.pdf, p47~
