Code help: Problem with SmartApp & Sunset
Would anyone mind taking a look at my SmartApp I wrote? I’m having trouble with my if statement that looks at the current time and verifies its equal to or after sunset and before sunrise in my def presencelightshome() statement. Everything else is WAD, it’s just the checking if its past sunset when someone arrives home (presence) that isn’t working.
I keep getting this error: a9549c0c-8dfd-4afc-bc5a-39d444981ccd 4:40:47 PM: error Cannot get property ‘time’ on null object
  • Light Control
  • Author: toby@cth3.com
  • Date: 1/2/14
  • Monitors a set of presence detectors and turns off a set of lights when everyone has left.
  • When at least one person returns home, turns on a set of lights if it’s after sunset.
  • Turns on a set of lights at sunset and turns off a set of lights at a specified time based on mode.
preferences {
section(“Monitor presence for these people”) {
input “people”, “capability.presenceSensor”, multiple: true
section(“When someone arrives turn on these lights”) {
input “presencelightson”, “capability.switch”, multiple: true
section(“When everyone has left turn off these lights”) {
input “presencelightsoff”, “capability.switch”, multiple: true
section(“At sunset turn on these lights”) {
input “schedulelightson”, “capability.switch”, multiple: true
section(“Turn these lights off according to schedule”) {
input “schedulelightsoff”, “capability.switch”, multiple: true
input “schedulemodehome”, “mode”, title: "Home mode"
input “scheduletimehome”, “time”, title: "Home mode time"
input “schedulemodeaway”, “mode”, title: "Away mode"
input “scheuletimeaway”, “time”, title: “Away mode time”
section(“Zip code (for sunrise/sunset)”) {
input “zip”, “decimal”, required: false
section(“False alarm threshold (defaults to 10 min)”) {
input “falseAlarmThreshold”, “decimal”, title: “Number of minutes”, required: false
section(“Notifications”) {
input “sendPushMessage”, “enum”, title: “Send a push notification?”, metadata:[values:[“Yes”,“No”]], required:false
def installed() {
init()
def updated() {
unsubscribe()
init()
def init() {
subscribe(location)
subscribe(people, “presence”, presence)
schedule(scheduletimehome, schedulelightshome)
schedule(scheduletimeaway, schedulelightsaway)
checkSun();
def checkSun() {
def zip = settings.zip as String
def locale = getWeatherFeature(“geolookup”, zip)
def timezone = TimeZone.getTimeZone(locale.location.tz_long)
def weather = getWeatherFeature(“astronomy”, zip)
def sunrise = weather.moon_phase.sunrise.hour + “:” + weather.moon_phase.sunrise.minute
def sunset = weather.moon_phase.sunset.hour + “:” + weather.moon_phase.sunset.minute
def current = weather.moon_phase.current_time.hour + “:” + weather.moon_phase.current_time.minute
def sunsetTime = timeToday(sunset, timezone)
def sunriseTime = timeToday(sunrise, timezone)
log.info(“Sunset: ${sunset}”)
log.info(“Sunrise: ${sunrise}”)
log.info(“Current: ${current}”)
schedule(timeToday(sunset, timezone), schedulelightssunset)
schedule(timeTodayAfter(new Date(), “01:00”, timezone), checkSun)
def presence(evt) {
if(evt.value == “not present”) {
log.debug(“Checking if everyone is away”)
if(everyoneIsAway()) {
log.info(“Starting lights off sequence”)
def delay = (falseAlarmThreshold != null && falseAlarmThreshold != “”) ? falseAlarmThreshold * 60 : 10 * 60
runIn(delay, “presencelightsaway”)
else {
if(anyoneIsHome()) {
log.info(“Checking if anyone is home”)
def presencelightshome() {
log.debug(“Checking if it’s dark out”)
if (now() >= sunsetTime.time || now() < sunriseTime.time) {
def message = "${app.label} turned on the lights because someone arrived home"
log.info(message)
send(message)
settings.presencelightson.on()
def presencelightsaway() {
def message = "${app.label} turned off the lights because everyone left home"
log.info(message)
send(message)
settings.presencelightsoff.off()
def schedulelightssunset() {
def message = "${app.label} turned on the lights because it is sunset"
log.info(message)
send(message)
settings.schedulelightson.on()
def schedulelightshome() {
if (location.mode==schedulemodehome) {
def message = "${app.label} turned off the lights because of schedule ${location.mode}"
log.info(message)
send(message)
settings.schedulelightsoff.off()
def schedulelightsaway() {
if (location.mode==schedulemodeaway) {
log.info(message)
send(message)
private everyoneIsAway() {
def result = true
if(people.findAll { it?.currentPresence == “present” }) {
result = false
log.debug(“everyoneIsAway: ${result}”)
return result
private anyoneIsHome() {
def result = false
result = true
log.debug(“anyoneIsHome: ${result}”)
return result
private send(msg) {
if(sendPushMessage != “No”) {
log.debug(“Sending push message”)
sendPush(msg)
log.debug(msg)
A few folks already created a SmartAPP like this…
I think the issue is that sunriseTime and sunsetTime are scoped to checkSun.
Any suggestions on the best way to fix it? I use the checkSun function to schedule turning on lights at sunset (and getting when sunset will be). A dirty way would be to put the same checkSun code in the presencelightshome function but that just seems messy to me.
You can save sunsetTime and sunriseTime to ‘state’, i.e.
def checkSun() {
   state.sunsetTime = sunsetTime
   if (now() >= state.sunsetTime.time ... )
Also, you may have to unschedule( checkSun ) before scheduling it again in checkSun. I think a schedule call doesn’t have any effect for already-scheduled or running functions. The log will show ‘scheduling…’ but the function won’t get run.
Thank you very much, I’ll give that a try!
Unfortunately that didn’t work:
dce9e392-b3fb-4c90-ba61-a0359d25f9f8 4:42:55 PM: error No such property: time for class: java.lang.String
Perhaps all values are serialized to primitive types. Try this instead then
def checkSun() {
   state.sunsetTime = sunsetTime.getTime()
   if (now() >= state.sunsetTime ... )
Hi C.Chen,
Thank you for your help. I was able to get the code to work by doing the following:
  state.sunriseTime = sunriseTime.time
  state.sunsetTime = sunsetTime.time
  if (now() >= state.sunsetTime || now() < state.sunriseTime)
