Co2 Pressure Switch Homebrew Protection
My need was to have a sensor that could send an alarm when the pressure in my Co2 Tank, which provides carbonation for my home brew, fell below 20 psi indicating the tank needed to be refilled.
Main
Components:
GoControl Z-Wave Door/Window Sensor - WADWAZ-1
Adjustable
Pressure Switch QPM11-NC (eBay)
The two main components with the cover removed from the door/window
sensor.
Marking location to cut plastic housing to align pressure switch pins to
magnetic sensor pins.
Remove
circuit board and cut out plastic housing.
These dimensions
may change depending on the components used, but were the measured dimensions of the cut out and hole
for this particular build.
Locate and
drill adjustment hole approximately 9/64” diameter.
Crush glass
magnet sensor with pliers and bend up the two wire pins to outside width of
switch pins.
Mount switch
and epoxy to housing.
Solder
circuit board pins to switch pins, install battery, and screw cover into place.
Completed
pressure switch mounted on gauge set. The switch adjustment screw was set to
close switch when pressure drops to 20 psi. I normally feed the secondary
regulators at 30 psi.
This is quite possibly the most important SmartThings project ever created. We can’t drink bad beer people!
Wow, Fuller this is awesome. I’m actually building one of these for myself. I bought the components you show in your post. I have a question however, is there a reason you broke the magnetic sensor vs using the screws at end of the board for existing sensors? I’m wondering if i should just solder 2 wires to the end of pressure switch and add the wires into those screws.
Thanks again for this post. This is really amazing.
