Hi All,
I have a 50 cubic meter Cistern (13,000Gallons) at our acerage and I would like to monitor the tank level %.
I have a Fortrezz MIMOlite which I have used the existing coding out there to get the unit to display Voltage.
The mimolite unit displays 0-5VDC. I have installed a level transmitter that is ranged 0-2.5meters for tank level.
First I was hoping to change the readout so that 0 volts = 0 meters and 5 volts = 2.5 Meters.
Second I was hoping to have a second display that calculates volume of a horizontal capsule based off the tank level, I realize this would take a lot of calculations as the volume is non-linear. The tank is 30ft long by 8ft tall and 8ft wide.
My background is in industrial automation so I’m unfamiliar with how to write the code for this.
Any help would be great, Thanks!
Jared
Below I have copied the existing code im using:
FortrezZ Flow Meter Interface
Copyright 2016 FortrezZ, LLC
Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0 -
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
for the specific language governing permissions and limitations under the License.
Based on Todd Wackford’s MimoLite Garage Door Opener
metadata {
// Automatically generated. Make future change here.
definition (name: "FortrezZ MIMOlite", namespace: "fortrezz", author: "FortrezZ, LLC") {
capability "Configuration"
capability "Switch"
capability "Refresh"
capability "Contact Sensor"
capability "Voltage Measurement"
attribute "powered", "string"
command "on"
command "off"
fingerprint deviceId: "0x1000", inClusters: "0x72,0x86,0x71,0x30,0x31,0x35,0x70,0x85,0x25,0x03"
simulator {
// Simulator stuff
preferences {
input "RelaySwitchDelay", "decimal", title: "Delay between relay switch on and off in seconds. Only Numbers 0 to 3.0 allowed. 0 value will remove delay and allow relay to function as a standard switch", description: "Numbers 0 to 3.1 allowed.", defaultValue: 0, required: false, displayDuringSetup: true
// UI tile definitions
tiles (scale: 2) {
standardTile("switch", "device.switch", width: 4, height: 4, canChangeIcon: false, decoration: "flat") {
state "on", label: "On", action: "off", icon: "http://swiftlet.technology/wp-content/uploads/2016/06/Switch-On-104-edit.png", backgroundColor: "#53a7c0"
state "off", label: 'Off', action: "on", icon: "http://swiftlet.technology/wp-content/uploads/2016/06/Switch-Off-104-edit.png", backgroundColor: "#ffffff"
standardTile("contact", "device.contact", width: 2, height: 2, inactiveLabel: false) {
state "open", label: '${name}', icon: "st.contact.contact.open", backgroundColor: "#ffa81e"
state "closed", label: '${name}', icon: "st.contact.contact.closed", backgroundColor: "#79b821"
standardTile("refresh", "device.switch", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
standardTile("powered", "device.powered", width: 2, height: 2, inactiveLabel: false) {
state "powerOn", label: "Power On", icon: "st.switches.switch.on", backgroundColor: "#79b821"
state "powerOff", label: "Power Off", icon: "st.switches.switch.off", backgroundColor: "#ffa81e"
standardTile("configure", "device.configure", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
valueTile("voltage", "device.voltage", width: 2, height: 2) {
state "val", label:'${currentValue}v', unit:"", defaultState: true
valueTile("voltageCounts", "device.voltageCounts", width: 2, height: 2) {
state "val", label:'${currentValue}', unit:"", defaultState: true
main (["voltage"])
details(["switch", "contact", "voltage", "powered", "refresh","configure"])
//log.debug “description is: ${description}”
def result = null
def cmd = zwave.parse(description, [0x20: 1, 0x84: 1, 0x30: 1, 0x70: 1, 0x31: 5])
//log.debug "command value is: $cmd.CMD"
if (cmd.CMD == "7105") { //Mimo sent a power loss report
log.debug "Device lost power"
sendEvent(name: "powered", value: "powerOff", descriptionText: "$device.displayName lost power")
} else {
sendEvent(name: "powered", value: "powerOn", descriptionText: "$device.displayName regained power")
//log.debug "${device.currentValue('contact')}" // debug message to make sure the contact tile is working
if (cmd) {
result = createEvent(zwaveEvent(cmd))
log.debug "Parse returned ${result?.descriptionText} $cmd.CMD"
return result
def updated() {
log.debug "Settings Updated..."
configure()
//notes about zwaveEvents:
// these are special overloaded functions which MUST be returned with a map similar to (return [name: “switch”, value: “on”])
// not doing so will produce a null on the parse function, this will mess you up in the future.
// Perhaps can use ‘createEvent()’ and return that as long as a map is inside it.
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
log.debug “switchBinaryReport ${cmd}”
if (cmd.value) // if the switch is on it will not be 0, so on = true
return [name: "switch", value: "on"] // change switch value to on
else // if the switch sensor report says its off then do...
return [name: "switch", value: "off"] // change switch value to off
// working on next for the analogue and digital stuff.
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) // basic set is essentially our digital sensor for SIG1
log.debug "sent a BasicSet command"
//refresh()
delayBetween([zwave.sensorMultilevelV5.sensorMultilevelGet().format()])// requests a report of the anologue input voltage
[name: "contact", value: cmd.value ? "open" : "closed"]}
//[name: "contact", value: cmd.value ? "open" : "closed", type: "digital"]}
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd)
log.debug "sent a sensorBinaryReport command"
refresh()
def zwaveEvent (physicalgraph.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd) // sensorMultilevelReport is used to report the value of the analog voltage for SIG1
log.debug "sent a SensorMultilevelReport"
def ADCvalue = cmd.scaledSensorValue
sendEvent(name: "voltageCounts", value: ADCvalue)
CalculateVoltage(cmd.scaledSensorValue)
// Handles all Z-Wave commands we aren't interested in
log.debug("Un-parsed Z-Wave message ${cmd}")
def CalculateVoltage(ADCvalue)
def map = [:]
def volt = (((1.5338*(10**-16))*(ADCvalue**5)) - ((1.2630*(10**-12))*(ADCvalue**4)) + ((3.8111*(10**-9))*(ADCvalue**3)) - ((4.7739*(10**-6))*(ADCvalue**2)) + ((2.8558*(10**-3))*(ADCvalue)) - (2.2721*(10**-2)))
//def volt = (((3.19*(10**-16))*(ADCvalue**5)) - ((2.18*(10**-12))*(ADCvalue**4)) + ((5.47*(10**-9))*(ADCvalue**3)) - ((5.68*(10**-6))*(ADCvalue**2)) + (0.0028*ADCvalue) - (0.0293))
//log.debug "$cmd.scale $cmd.precision $cmd.size $cmd.sensorType $cmd.sensorValue $cmd.scaledSensorValue"
def voltResult = volt.round(1)// + "v"
map.name = "voltage"
map.value = voltResult
map.unit = "volts"
return map
def configure() {
def x = (RelaySwitchDelay*10).toInteger()
log.debug "Configuring.... " //setting up to monitor power alarm and actuator duration
delayBetween([
zwave.associationV1.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format(), // FYI: Group 3: If a power dropout occurs, the MIMOlite will send an Alarm Command Class report
// (if there is enough available residual power)
zwave.associationV1.associationSet(groupingIdentifier:2, nodeId:[zwaveHubNodeId]).format(), // periodically send a multilevel sensor report of the ADC analog voltage to the input
zwave.associationV1.associationSet(groupingIdentifier:4, nodeId:[zwaveHubNodeId]).format(), // when the input is digitally triggered or untriggered, snd a binary sensor report
zwave.configurationV1.configurationSet(configurationValue: [x], parameterNumber: 11, size: 1).format() // configurationValue for parameterNumber means how many 100ms do you want the relay
// to wait before it cycles again / size should just be 1 (for 1 byte.)
//zwave.configurationV1.configurationGet(parameterNumber: 11).format() // gets the new parameter changes. not currently needed. (forces a null return value without a zwaveEvent funciton
def on() {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(), // physically changes the relay from on to off and requests a report of the relay
refresh()// to make sure that it changed (the report is used elsewhere, look for switchBinaryReport()
def off() {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(), // physically changes the relay from on to off and requests a report of the relay
def refresh() {
log.debug “REFRESH!”
delayBetween([
zwave.switchBinaryV1.switchBinaryGet().format(), //requests a report of the relay to make sure that it changed (the report is used elsewhere, look for switchBinaryReport()
zwave.sensorMultilevelV5.sensorMultilevelGet().format()// requests a report of the anologue input voltage
