Hi,
I modified a DH (Simulated temperature sensor) but in ST app in the tile I have always “Checking status” …
What is the problem?
How I can solve?
* Copyright 2014 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
// Automatically generated. Make future change here.
definition (name: "My tile value", value: "giamma/testing", author: "Giamma") {
capability "Temperature Measurement"
command "setTemperature", ["number"]
// UI tile definitions
tiles {
valueTile("temperature", "device.temperature", width: 2, height: 2) {
state("temperature", label:'${currentValue}', unit:"F",
backgroundColors:[
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
main "temperature"
details("temperature","up","down")
// Parse incoming device messages to generate events
def pair = description.split(":")
createEvent(name: pair[0].trim(), value: pair[1].trim(), unit:"F")
def installed() {
initialize()
def updated() {
initialize()
def initialize() {
sendEvent(name: "DeviceWatch-DeviceStatus", value: "online")
sendEvent(name: "healthStatus", value: "online")
sendEvent(name: "DeviceWatch-Enroll", value: [protocol: "cloud", scheme:"untracked"].encodeAsJson(), displayed: false)
if (!device.currentState("temperature")) {
setTemperature(getTemperature())
def setLevel(value, rate = null) {
setTemperature(value)
def setTemperature(value) {
sendEvent(name:"temperature", value: value)
private getTemperature() {
def ts = device.currentState("temperature")
Integer value = ts ? ts.integerValue : 72
return value
