Change in Routines
Samsung Smartthings routines used to allow checking to see “if all conditions are met” or “if any conditions are met” prior to then adding conditions. That suddenly is no longer available. Thoughts.
Waiting for two conditions to be added before asking how to combine them doesn’t seem unreasonable, and if you remove one of the conditions the All/Any setting is remembered if you add another one.
I think what he means is any/all preconditions. Someone in a German forum was trying to do this:
If any of the windows are open and when the button is pressed, send a message.
Oh right. I didn’t realise that had ever been implemented. Shows how little I use routines.
It’s not. See the missing any/all selector on the top of the preconditions? Currently all of the preconditions must be met.
I could swear that this was once possible.
It was. I still have a few Routines that contain when all or when any.
What I meant is that to me nothing has changed because I don’t remember All/Any ever being implemented for preconditions. It isn’t something I would notice though.
But for pre- conditions? For trigger conditions always but not sure on that one…
This is a screen shot of a current routine. I have not yet had a chance to see if it still works. I also have one for heat. Additionally, there is no longer a condition for " equal to or less than"
MrBlz
Bill
(attachments)
I can’t see anything unusual about it. Are you suggesting you can no longer create Routines like this? I certainly can.
Again you’ve lost me. I’m thinking of this …
Thank you. The error was on my end. Very embarrassing mistake on my part.
Indeed, because no one here has ever made a mistake like that before. :wink:
