I’ve been following you and reading on this platform for few weeks now and, I’ve decided to jump in the future
I’ve ordered 2 lights switchs Homeseer HS-WS100+ and they work great. We have also ordered the HS-WD100+ and his companion (HS-WA100+) to be install as a three ways dimmer switchs.
After taking a look in the manual, I’ve look on YouTube and I’ve found out those videos about how to install those devices (Ge/Jasco and Homeseer look really the same…).
12723: GE Add On switch
I’ve followed the steps and I can get only the dimmer working. The add-on switch doesn’t seen to get any power.
I’m starting to think that the add-on might be defective… But since I’m not an expert yet, I was hoping to get your advice about it.
I haven’t looked at it specifically, but GE/Jasco switches are wired differently than most other switches. I wouldn’t use a video of theirs for any other brand.
In particular, note that the position of the traveler wire and the neutral wire are usually reversed in the GE relative to most other switches. So if you’re following the GE guide, you would wire the Homeseer switch incorrectly.
Here’s the homeseer manual:
And here’s the GE. Note the position of the traveler relative to the ground is different than the Homeseer:
Have you tried getting in touch with homeseer support?
