Can Visonic MCT-340 **Temperature** show in favorites? ( instead of open/close state)
If you don’t care about knowing the open/close status at all, you can switch the device type in the IDE to “SmartSense Temp/Humidity Sensor”. If you still want to use it as a contact sensor, you can create a modified device handler using the instructions given here (ignore that this is for an Iris sensor; both sensors use the same SmartSense device handler):
