I’m trying to call the Azure Log Analytics Log Collector API with a SmartThings Smart App, however I keep on getting a 403/forbidden, and now I’m stuck after battling with this for a week or so. Can anyone see any obvious mistakes I’ve made in the code? Thanks very much in advance… been stuck on this for about 2 weeks and I’m at my wits end…
import javax.crypto.Mac;
import javax.crypto.spec.SecretKeySpec;
import java.security.InvalidKeyException;
import biz.source_code.base64Coder.Base64Coder
import groovyx.net.http.ContentType//Update customer Id to your OMS workspace ID
def customer_id() {return “xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx”}
def shared_key() {return “xxxxxxxxxxxxxxxxxxxxxxxxxxx”}
def log_type() {return “SmartThings_test”}
def content_type() {return ‘application/json’}def GetUTCDateNow() {return new Date().format("MM/dd/yyyy'T'HH:mm:ss.SSS'Z'")} def rfc1123date() {return new Date().format("E, dd MMM yyyy HH':'mm':'ss 'GMT'")}
// Build & send request to POST API
def Date getNowUTC(){
Calendar cal = Calendar.getInstance();
cal.setTimeZone(TimeZone.getTimeZone(“UTC”));
System.out.println(cal.toString());
Date now = cal.getTime();
return now;
}def hmac_sha256(String secretKey, String data) {
try {
Mac mac = Mac.getInstance(“HmacSHA256”)
SecretKeySpec secretKeySpec = new SecretKeySpec(secretKey.getBytes(), “HmacSHA256”)
mac.init(secretKeySpec)
byte[] digest = mac.doFinal(data.getBytes())
return digest
} catch (InvalidKeyException e) {
throw new RuntimeException(“Invalid key exception while converting to HMac SHA256”)
log.debug “Invalid key exception while converting to HMac SHA256”
}def build_signature(customer_id, shared_key, date, content_length, content_type){
def x_headers = “x-ms-date:” + date
def method = "POST"
def escapechar = "\n"
def string_to_hash = method + escapechar + content_length.toString() + escapechar + content_type + escapechar + x_headers + escapechar + "/api/logs"
def bytes_to_hash = string_to_hash.getBytes(“UTF-8”)
def decoded_key = shared_key.decodeBase64()
def hmac = hmac_sha256(decoded_key.toString(), string_to_hash.toString())
def encoded_hash = hmac.encodeBase64()
def authorization = "SharedKey " + customer_id + “:” + encoded_hash
return authorization}def sendEvent(sensorId, sensorName, sensorType, value) {
def cleanedSensorId= sensorId.replace(" ", “”)
def strBody = "{ sensorId : “${cleanedSensorId}”, sensorName : “${sensorName}”, sensorType : “${sensorType}”, value : “${value}” }"
def content_length = strBody.length()
def signature = build_signature(customer_id(), shared_key(), rfc1123date(), content_length, content_type())
def apiURI = “https://” + customer_id() + “.ods.opinsights.azure.com/api/logs?api-version=2016-04-01”log.info "uri: " + apiURI log.info "Body: " + strBody log.info "content_length: " + content_length log.info "signature: " + signature def params = [ uri: apiURI, contentType: "application/json", headers: ["Authorization": signature, "Log-Type": log_type(), "x-ms-date": rfc1123date()], body: strBody ] log.info "Params:: " + params try { httpPost(params) { resp -> log.debug "response data: ${resp.data}" log.debug "response contentType: ${resp.contentType}" } } catch (e) { log.debug "something went wrong: $e" }
sendEvent(‘test’,‘test’,‘test’,1)
