Hi has anyone got one of these working?
Does it need a custom DTH?
Ordered from https://www.aliexpress.com/item/1005002661211427.html
Thanks.
I’ll be honest: this is one of the things I hate about AliExpress. This looks like yet another rebranded tuya switch, which is fine. But they make both a Wi-Fi version and a Zigbee version, not a version that has both that I know of. So which is this specific one, Wi-Fi, or Zigbee?
Thanks for your reply. This one is zigbee.
All this stores’ zigbee items Smart ZigBee Series - Shop Cheap Smart ZigBee Series from China Smart ZigBee Series Suppliers at BSEED Official Store on Aliexpress.com
OK, if it’s Zigbee you are likely to run into an issue that affects all of the Tuya made Zigbee switches, which is that they use a proprietary cluster to handle their multi endpoint devices. So it’s very likely that the first gang will work, but the other two will not.
There is custom Groovy code that people have working with some versions of this device, but each individual reseller can change the firmware somewhat and the existing versions may not work with the one you have. So it can Be a lot of work ahead.
The most recent discussion on this, but for a different brand, is in the following thread. It’s possible that that device handler might work with your switch, but then again it might not. And of course all of this will have to be completely rewritten for the new edge architecture, but at the current time, that does not support multi gang switches.
[Device Handler] Moes 3 gang Zigbee wall switch ( cluster EF00)
I’ll be honest, if it was me I wouldn’t be investing in tuya Zigbee switches at this time, I would wait until there was an edge driver for them. But obviously it’s your choice.
Thank you.
I have been reading that thread and a lot of others!
I will try some different dths until something hopefully works.
I’m still waiting for delivery.
Ohh!..I’ve been looking for a switch of this brand as well, since I want to install tactile zigbee switches and there are not many brands available, in fact I am looking for a specific one that comes with an integrated outlet but there are not many brands that have it. Except for Livolo, but the Zigbee version of Livolo is not compatible with SmartThings, the BSEED brand seems to be, according to what the Aliexpress seller told me.
Could you comment what was your experience with this switch when you got it?
I created a topic about this asking the same thing as you a few months ago but nobody answered me.
Hey. What finally happened?
This week I finally got these Bseed zigbee 3 gang and 2 gang switches installed by an electrician.
As I needed for them to just work I also installed a Tuya Zigbee Hub. I then added them in Smartthings via Smartlife.
There are some weird duplications however I got the lights working in automations.
I will try playing around with adding directly to ST when I get a chance.
Bseed 3 gang zigbee now connected directly to ST Hub and working with edge drivers. Works with two different drivers at once as this 3 gang is effectively a 2 gang and 1 gang in the same housing.
The 2 gang part uses the zigbee multi switch driver here
The 1 gang part uses the zigbee switch driver here
It turns out I’m in a similar situation. I have the same Bseed Zigbee light switches. Is there still a way for me to access the drivers you shared? I tried opening the link, but I keep getting a 403 Forbidden error.
Just tried it, works for me, can you try again?
Thank you for checking the link for me! Unfortunately, I keep getting a 403 Forbidden message. Should this link work as an invitation, or is it just for accessing the channel? I wonder if I might be missing the correct invitation link.
Try link on this page.
Yes, everything works now! I really appreciate your time in helping me with those drivers. Thank you!
Links that have “Callaway” in the URL will work after you have subscribed to the channel, but will give an error message before then.
Instead, share the same link that you used to first subscribe. These will usually have “Bestow” in the URL.
I’d also like to share my findings with Mariano’s Shared Beta Driver “Zigbee Multi Switch and Child Mc.” It works well with BSEED light switches - I tested it myself with a two-gang switch.
