I successfully connected my Bosch Smart Home Controller II hub to Smartthings via Matter. Currently, my Samsung Frame TV acts as a Smartthings/Matter hub. After connecting, I was able to import most of my Bosch devices, except the roller shutter controls. I tried the same with Homekit and Google Home (both via Matter), and these systems can see the roller shutter controls. Is this a Smartthings limitation, or do I need to install a dedicated hub instead of using just the TV?
The list of devices bridged by the Bosch Controller II:
Matter 1.1, by the way.
Bridged devices (German, too lazy to translate):
Bewegungsmelder
Dimmer
Heizkörper-Thermostat / Heizkörper-Thermostat II
Raumthermostat / Raumthermostat II
Raumthermostat Fußbodenheizung / Raumthermostat II 230 V
Relais
Tür-/ Fensterkontakt / Tür-/ Fensterkontakt II / Tür-/Fensterkontakt II Plus
Zwischenstecker / Zwischenstecker kompakt
Motion detector, dimmer, thermostats, contact sensors, plug.
OK, so there is no shutter/blinds controller in Matter 1.1. But Smartthings is already on 1.3, isn’t it?
Also, how do these blinds appear when I connect my Bosch Hub with Apple and Google Home (also via Matter)? I’m getting confused
Any workaround to solve this?
The shutters are Zigbee, as far as I know. You could try to add them directly to your SmartThings hub.
Hi, @megatomi
Welcome to the SmartThings Community!
Could you help us collect some information, please?
- Try to install over Matter those devices, once it fails, please submit the logs of your hub
Here are the instructions
- In the my.smartthings, enter “your hubs”
- Enter the corresponding Hub
- Click on “Dump Hub Logs”
- Change the reason for requesting hub logs if needed
- Confirm that the request is submitted
Note: If you have more than one Hub, the name of the one involved in the issue.
- Share the timestamp when you tried to install them including your timezone like GMT-6
- Open support access to your account
- Confirm the email account registered in the forum is the same one you use for SmartThings. If not, please share it with me over DM.
- Enable support access to your account:
- Go to the SmartThings Web (my.smartthings.com)
- Log in to your Samsung Account
- Select Menu (⋮) and choose Settings
- Toggle on Account Data Access
- Select the time period and confirm - In this step, please select “Until turned off”, once the team finishes, we’ll let you know so you can disable it again.
