How come? Would like to hear your feedback.
Lowes (November 26 - December 2, 2020)
- Google Nest Mini $19
- Google Nest Hub $50
- Google Nest Audio Smart Speaker $100
- Echo Dot (3rd gen) $19
- Echo Show 8 $65
- Echo (3rd gen) $100
- Ring Indoor Security Camera $45
- Ring Stick Up Security Camera $80
- Arlo Essential Spotlight Indoor Security Camera (Wired or Wireless) $100
- Ring Spotlight Outdoor Security Camera $150
- Ring Outdoor Security Camera Floodlight $190
- Ring Video Doorbell 3 $139
- Ring Home Security System $150
- Google Nest Hello Video Doorbell $179
- Google Nest Thermostat $199
- Ring Video Doorbell Pro $170
- Echo Show 5 $45
As noted before, not all items may integrate with ST. It is your responsibility to fully investigate devices before purchasing.
regarding the ring camera, when you install it, it updates the firmware right away and there is no way to stop it. there is a good chance that the firmware update will brick the camera. this has happened to a lot of people and it happened to one of my cameras. then you have no choice but to return/exchange it.
Konnected 20% off (November 11-30, 2020)
Staples (November 22-28, 2020)
- Google Chromecast $19
- Echo Show 5 $45
- Amazon Fire Tablet 10 $80
- Google Home Mini $19
- Amazon Echo Dot 4th gen $29
- and a couple of label makers for @JDRoberts
Newegg (November 23-27, 2020)
- Arlo Pro 3 2-Camera Security System $300
- Nest Thermostat 3rd gen $199
- Nest Hello $179
IDevices has started their Black Friday sale with a number of devices at 30% off. These are Wi-Fi, no bridge required. they also have some Bluetooth Remotes. Integration with smartthings is through IFTTT, Amazon routines, or homebridge.
They have an in wall outlet that has two independently controlled sockets, a nice device. Itâs usually priced at $99, which is obviously expensive. Itâs on sale at $63, which is a lot, but again, two independently controlled sockets.
It meets standard US code specifications, supporting 15 A or a 1/2 hp motor. So thatâs significantly better than most plug-in pocketsockets.
If youâre looking for something to integrate with smartthings, I wouldnât select their switches since thereâs no way to get a status update if the switch is changed at the wall. But thatâs not an issue for outlets, so this might be a candidate, especially if youâre looking for something where each individual socket is controllable and youâre OK with a cloud connection.
I have some of their devices working with Homekit that I bought a couple of years ago. Iâve since switched over to Meross for Pocketsockets: they are less expensive and have an official Integration with smartthings. But Meross doesnât have an in wall outlet yet, so if youâre looking for one, this could be a candidate.
you can sign up to receive the black friday deals from Sinope Technolgies
Duke energy black friday sale for customers - Ecobee 3 for $89.00, Ecobee4 for $149
Target
- Echo 4th gen $70
- Echo Dot 4th gen $29
- Ring Video Doorbell 3 $140
- Echo Show 5 $45
- Ring Indoor Cam $90
- Amazon Fire 10 32gb tablet $80
Office Depot/Office Max (November 26-28, 2020)
- APC Back-UPS $35
iBlinds black friday sale is live. $118 + shipping for the kit with a solar panel
Thereâs a filter for smart home items in Black Friday deals week at Amazon, but for some reason itâs not on the main navigation page:
Most Aqara devices have a coupon box on the Amazon product page today for 15 to 20% off.
Most of the basic sensors, including the door sensor, the motion sensor, and the humidity sensor, can be used with a smartthings hub instead of the aqara gateway, although they may require custom code.
Historically, these devices have had issues getting messages through some Zigbee repeaters, which means they work fine if they connect directly to your hub or through an IKEA Tradfri bulb or pocketsocket, but they may keep dropping off line if they are connecting through other zigbee devices. So just something to be aware of.
Not all of their devices work with smartthings, for example the new camera does not, so check the forum to make sure the model you are interested in does work.
The humidity sensor, in particular, is a device which doesnât have much competition right now in the under $20 price range. It says it requires the aqara hub, but you can use the smartthings hub instead. Todayâs 15% off coupon brings the price down to $17.
(Also note that although all of the individual devices will say they also work with Apple HomeKit, that is only true if they are connected to an aqara gateway, so if you are using them with smartthings they wonât work with Homekit.)
Meross dual plug (2 pack) $32
of course I wanted to purchase the outdoor plug for homekit and they are out of stock
fyi⌠the sonos beam and sub are $100 off at most merchants
Upgrade now and get up to 33% off your first payment! Offer expires 11/30.
