This is not correct, I own the Leviton switches/dimmers and they work just as a decora switch/dimmer. Up/down for on/off and have a dimmer rocker next to the switch for brightness. Most people know how a regular dimmer works which is the same way, people may not know to hold down the GE switch to control the dimmer instead of a separate dimmer rocker. This was the main reason I got these, so that people that enter my house can use a familiar type of dimmer without the automation. Although I use motion control for my lighting anyways, so it would not be that big of a deal.
Ah this makes sense. I have only had the latest ones, didnāt know they changed the design. I wouldnāt have bought the old ones if that was the case.
Are these Leviton the best around? Iāve had recommendations for Lutron and Noon in the last 24 hours. Noon seems like a non-starter because I want to use SmartThings and not thru IFTTT. But they do look nice.
Donāt need one. Ecobee switch+ is live in the marketplace. The Noon switches are indeed very nice, high quality pieces, but no SmartThings integration. I have virtual switches through IFTTT with mine for some basic automations that dont require a speedy response time.
I like Lutron because they are excellent switches and they will work with Alexa or on their own even when smartthings is down. But it just depends on what your own priorities are.
Have you had a chance to look at the device class features FAQ?
I use MiHome Smart Switches for my lighting (no neutral wire required) and MiHome Sockets for the power rings in my house. These switches fit in UK standard (deep) pattress boxes which makes swapping them simple.
Switching is by radio control (operating in the 433MHz ISM short-range band using OOK modulation) or manually by pressing the button on the housing. It is compatible with the Amazon Echo for voice and remote activation.
I have only had them in for a couple of months so donāt know how long they will last but so far they are fine.
Since this forum is for those who are using the Samsung SmartThings home automation platform, what are you using to integrate the mihome devices with SmartThings, and are you consistently getting two way status updates? SmartThings doesnāt have a 433mhz radio, so there is no direct integration.
There is no direct integration and that is my problem with many of this new technology the lack of integration.
There are many well designed products out there which cannot be integrated with other things without a lot of head scratching and hard work.
The manufactures do not provide integration but the skilled individuals on groups like this often come up with answers when their interest in something is aroused.
I donāt have the answers, I am stumbling round and round in circles with smartthings unable to control even the smartthings products that came in my hub starter pack, yet I have managed to integrate other āsmartā products with relative ease.
I intend to persevere and will get my head round smartthings eventually but until then I am relying on groups like this for ideas and hopefully a few solutions.
Thanks There is no direct integration and that is my problem with many of this new technology the lack of integration.
While I recognize that Leviton makes a great product, I prefer the GE switch in some circumstances where a LED indicator is of value. The GE switch has an LED that can be configured to be on, off or never on when switched on. I use these with the LED configured to be on when the switched lights are on for a porch light and a basement light. A quick glance at the switch tells me whether the switched lights are on or off.
Conversely, setting the LED to be on when the switch is off is a great switch locator for a dark room.
Iām using the Leviton wifi 3-way dimmer switches in my home. I bought wifi because I was a newb and didnāt know what I was doing yet, or i would have bought zwave. Fortunately they still work fine using either the smartthings app or google assistant voice commands. I have access to on/off and brightness through smartthings but if I want other settings I have to use the leviton app. Overall they are great switches, and prefer the design of them over most other manufacturers.
