Hi all, I have read around various threads on the forum to find out which amp can be best controlled by ST.
[RE-RELEASE] Denon Network AV Receivers was useful but didn’t give me the answer I need.
The audio shop has recommended that I should get a Denon AVR-X4300H. Can anyone confirm that I will be able to control this amp with ST please? Here is a quick paste from the device spec sheet:
The AVR-X4300H can also be set up and operated by a home computer on the network via IP control, either via wired LAN connection or via Wi-Fi wireless connection. For direct connection to external home automation and control equipment, the AVR-X4300H is equipped with an RS-232C serial port. The AVR-X4300H also features Crestron Connected certification for quick and easy integration with Crestron home automation equipment.
Really appreciate your help…
