Bathroom vent automation
You should never use a light dimmer switch for a fan motor. If the fan is wired in such a way that it is not actually drawing current from the circuit controlled by the fan then that’s an entirely different situation.
If the fan is just on/off, not variable speed, you can probably use a regular on/off switch as long as all the other ratings match.
This applies in the UK as well:
