Here’s the most recent version of my code. This works around the problem by deferring the setup until later, rather than trying to do it once at initialization/update. I’m new to Groovy, so please excuse any ugliness:
* External Web Service
* Author: bod@bod.org
* Date: 2014-02-25
import groovy.json.JsonBuilder
preferences {
section("Which devices should be available?") {
input "sensor", "capability.sensor", title: "Which sensors?", multiple: true, required: false
input "presenceSensor", "capability.presenceSensor", title: "Which presence sensors?", multiple: true, required: false
input "actuator", "capability.actuator", title: "Which actuators?", multiple: true, required: false
input "switches", "capability.switch", title: "Which switches?", multiple: true, required: false
input "colorControl", "capability.colorControl", title: "Which color controls?", multiple: true, required: false
input "musicPlayer", "capability.musicPlayer", title: "Which music players?", multiple: true, required: false
input "alarm", "capability.alarm", title: "Which alarms?", multiple: true, required: false
input "energyMeter", "capability.energyMeter", title: "Which energy meters?", multiple: true, required: false
input "indicator", "capability.indicator", title: "Which indicators?", multiple: true, required: false
input "powerMeter", "capability.powerMeter", title: "Which power meters?", multiple: true, required: false
input "smokeDetector", "capability.smokeDetector", title: "Which smoke detectors?", multiple: true, required: false
input "carbonMonoxideDetector", "capability.carbonMonoxideDetector", title: "Which CO detectors?", multiple: true, required: false
input "thermostat", "capability.thermostat", title: "Which thermostats?", multiple: true, required: false
section("or select by capability") {
input "accelerationSensor", "capability.accelerationSensor", title: "Which acceleration sensors?", multiple: true, required: false
input "battery", "capability.battery", title: "Which battery levels?", multiple: true, required: false
input "button", "capability.button", title: "Which buttons?", multiple: true, required: false
input "configuration", "capability.configuration", title: "Which configurations?", multiple: true, required: false
input "contactSensor", "capability.contactSensor", title: "Which contact sensors?", multiple: true, required: false
input "illuminanceMeasurement", "capability.illuminanceMeasurement", title: "Which illuminance measurements?", multiple: true, required: false
input "imageCapture", "capability.imageCapture", title: "Which image captures?", multiple: true, required: false
input "locationMode", "capability.locationMode", title: "Which location modes?", multiple: true, required: false
input "lock", "capability.lock", title: "Which locks?", multiple: true, required: false
input "lockCodes", "capability.lockCodes", title: "Which lock codes?", multiple: true, required: false
input "momentary", "capability.momentary", title: "Which momentaries?", multiple: true, required: false
input "motionSensor", "capability.motionSensor", title: "Which motion sensors?", multiple: true, required: false
input "polling", "capability.polling", title: "Which pollings?", multiple: true, required: false
input "refresh", "capability.refresh", title: "Which refreshes?", multiple: true, required: false
input "relativeHumidity", "capability.relativeHumidityMeasurement", title: "Which relative humidity sensors?", multiple: true, required: false
input "signalStrength", "capability.signalStrength", title: "Which signal strengths?", multiple: true, required: false
input "switchLevel", "capability.switchLevel", title: "Which switch levels?", multiple: true, required: false
input "temperatureMeasurement", "capability.temperatureMeasurement", title: "Which temperature sensors?", multiple: true, required: false
input "threeAxis", "capability.threeAxis", title: "Which three axis sensors?", multiple: true, required: false
input "tone", "capability.tone", title: "Which tones?", multiple: true, required: false
input "valve", "capability.valve", title: "Which valves?", multiple: true, required: false
input "waterSensor", "capability.waterSensor", title: "Which water sensors?", multiple: true, required: false
mappings {
path("/events/:id") {
action: [
GET: "showEvents"
path("/devices") {
action: [
GET: "showDevice"
path("/device/:id") {
action: [
GET: "showDevice",
PUT: "updateDevice"
path("/subscriptions") {
action: [
GET: "showSubscription"
path("/subscription/:id") {
action: [
GET: "showSubscription",
POST: "subscribeToDevice",
DELETE: "unsubscribeDevice"
path("/subscribe/:id") {
action: [
def allDevices() {
def deviceMap = [:]
def deviceList =
[ accelerationSensor, actuator, alarm, battery, button, colorControl,
carbonMonoxideDetector, configuration, contactSensor, energyMeter,
illuminanceMeasurement, imageCapture, indicator, locationMode, lock,
lockCodes, momentary, motionSensor, musicPlayer, polling, powerMeter,
presenceSensor, refresh, relativeHumidity, sensor, signalStrength,
smokeDetector, switches, switchLevel, temperatureMeasurement, tone,
thermostat, threeAxis, valve, waterSensor
].flatten()
deviceList.retainAll( { it } )
deviceList.unique( { it?.id } )
deviceList.each{ deviceMap.putAt(it.id, it) }
return deviceMap
def installed() {
state.devices = [:]
state.webhooks = [:]
//state = allDevices()
//state.devices.each { log.debug "$it" }
log.trace "Installed"
def updated() {
state.devices = [:]
log.trace "Updated"
def uninstalled() {
log.trace "Uninstalled"
// this handler is subscribed with SmartThings to receive device events
// when called, it POSTs the event (as json) to the webhook subscribed for that device
def deviceHandler(evt) {
if (!state.devices) {
state.devices = allDevices()
log.debug "Updated device list"
def webhook = state.webhooks[evt.deviceId]
if (webhook) {
httpPostJson(uri: webhook, path: '', body: [evt: [value: evt.value]]) {
log.debug "Event data posted"
} else {
log.debug "Event handler called, but $evt.deviceId is not subscribed"
def showEvents() {
log.debug "showEvents, request: ${request.JSON}, params: ${params}"
log.debug "showEvents populated device list"
def json = new JsonBuilder( theDevice.events(params) )
if (params.id) {
def theDevice = state.devices[params.id]
if (theDevice) {
json( theDevice.events(params) )
else {
return httpError(404, "$params.id not found")
return json.content
def showSubscription() {
log.debug "showSubscription, request: ${request.JSON}, params: ${params}"
def json = new JsonBuilder()
if (params.id) {
if (state.webhooks[params.id]) {
json.call( [ 'id' : params.id, 'url' : state.webhooks[params.id] ] )
} else {
return httpError(404, "$params.id not subscribed")
} else {
log.debug "webhooks: $state.webhooks"
json.call( state.webhooks )
return json.content
def subscribeToDevice() {
log.debug "subscribeToDevice, request: ${request.JSON}, params: ${params}"
log.debug "subscribeToDevice populated device list"
if (params.id) {
def theDevice = state?.devices[params.id]
if (theDevice) {
def callbackUrl = request.JSON?.url
if ( state?.webhooks[theDevice.id] ) {
log.debug "$device.displayName already subscribed, unsubscribing first"
unsubscribe(theDevice)
log.debug "Subscribing $theDevice.displayName ($theDevice.id) to " + callbackUrl
state?.webhooks[theDevice.id] = callbackUrl
subscribe(theDevice, theDevice.supportedAttributes, deviceHandler)
} else {
} else {
return httpError(400, "a device ID is required")
def unsubscribeDevice() {
log.debug "unsubscribeDevice, request: ${request.JSON}, params: ${params}"
if (params.id) {
def webhook = state.webhooks[params.id]
if (webhook) {
log.debug "Unsubscribing $params.id"
state.webhooks.remove(params.id)
} else {
} else {
def showDevice() {
log.debug "showDevice, request: ${request.JSON}, params: ${params}"
def returnValue
log.debug "showDevice populated device list"
if (params.id) {
if (theDevice) {
log.debug "(show device $params.id)"
returnValue = [ theDevice.flatten(), theDevice.capabilities ]
else {
} else {
log.debug "(show all devices)"
returnValue = state.devices.collect( { k,v -> v } )
log.debug "$returnValue"
return returnValue
def void updateDevice() {
log.debug "updateDevice, request: ${request.JSON}, params: ${params}"
log.debug "updateDevice populated device list"
def command = request.JSON?.command
if (command) {
if (theDevice) {
theDevice."$command"()
} else {
I’m about to return my SmartThings kit, have moved onto other things. If I may be so bold as to offer some feedback:
a) please consider creating a device type that’s an ‘official’ REST endpoint. Nothing fancy, just the usual mix of REST,OAuth,JSON and webhook support. Then SmartApps can help the outside world interact with the SmartThings world. I’m sure one day SmartThings will take over the world, but in the meantime, extend your reach by making it easy to connect with stuff outside your ecosystem. Another upside: if you implement it, then you’ll retain the ability to make it secure (e.g. against DDOS), behaves correctly, is an efficient use of your resources, etc. On the other hand, if you make external developers implement their own, you’ll end up with multiple implementations, each with their own imperfections. Sounds like a recipe for unnecessary pain and suffering.
b) please provide a method to get the device wrapper, given a device ID. Hopefully it’s obvious why
c) if ‘state’ is the only persistent storage available, expect it to be abused in all kinds of unnatural ways
If it’s not very robust, can I ask that you either make it so, or improve the error reporting so external developers can tell what broke and why?
d) I was looking for less granular capabilities to define which devices the user could specify to use with my SmartApp. I ended up enumerating capabilities, and the code is much uglier as a result (as you can see). I did find ‘sensor’ and ‘actuator’, but with no documentation, and insufficient devices to discover their definition empirically, I was hesitant to rely on them.
Anyhow, hope this helps (it’s meant constructively).
