Trying to get my head wrapped around this but the ideal is…
When presence 1 or 2 shows up… then if door 1 or 2 opens… then if motion sensor goes active… speak.
Using various standalone conditions and triggers work just fine in their component parts. I can’t seem to be able to string it together. A side shoot is I’m also trying to understand under what circumstances a piston waits for the next event.
For example, if I used Followed By, does it wait indefinitely for that trigger or if something else happens like a switch is thrown does the piston reset? Same thing about the Then-If…
My ap[quote=“8BitNinja, post:1, topic:73998”]
[/quote]
My approach, though probably not the most efficient due to my limited experience, would be:
Basic Piston
IF motion sensor changes to active AND contact sensor changed in the last {expected time between opening door and passing sensor} AND presence changed in the last {expected time between arrival and passing sensor} THEN speak. .
You could probably use an ELSE-IF for that. Just speculating, as it’s bed time, and I’m too sleepy to open Core:
ELSE-IF Piston
IF (motion AND Presence1 changed in the last X minutes) AND GROUP [Any of Door1 or Door2 contact changed in the last X minutes] THEN speak to Presence1
ELSE IF (motion AND Presence2 changed in the last X minutes) AND GROUP [Any of Door1 or Door2 contact changed in the last X minutes] THEN speak to Presence2
Thanks, I think I’ll handle the “who” presence separately by running a piston that evaluates between both, one or the other is present and sets a string variable with “sir”, “ma’am” or “everyone”. I think in concept that might work – then I just reference the variable in the “speak”.
Something like this maybe.
The 10 minute window for the variable is if I’m walking home and perhaps have a chat with the neighbour.
You can add a door sensor in as well.
