Are there any Edge drivers for door open/close/contact sensors?
Among general searching, I’ve also looked at the following resources and am not seeing anything:
There’s a community-created channel from one author that has the Aqara contact sensors in it, and there’s a virtual version in Edge Creator, but that’s all I’ve seen so far.
Both are on the quick browse lists you mentioned.
The SmartThings beta channel that you linked to on Github has a Zigbee Contact driver that supports a range of devices previously supported in stock handlers.
That said I don’t currently recommend it for the Sonoff as it falls offline with inactivity.
Actually the latest version of @Mariano_Colmenarejo Edge driver seems to work well with the Sonoff contact sensor.
Opening this up again. Does anyone else thing it’s weird there’s still no generic edge driver for a z-wave open/close sensor? (Or is there and I am missing it?)
Doesn’t the Z-Wave Sensor cover that?
I’m also trying to add Fibaro Door Sensor 2 to brand new Aeotec Hub but it recognized as termostat valve
It did not seem to, no.
