Also is there a way to create a small graph or keep track of data? It would be useful to know if the sump pump ‘duty cycle’ is unusual (100% or 0%) so being able to look at data by hour would help.
I don’t have ST yet but about ready to buy one. Want to make sure I can make it do what I want before I spend the money
@kevin for your graph question you can use ThingSpeak = Graphing from Smartsense Multi florianz made an app that will export the sensor’s readings to a graph. I use it for temperature and power readings on several of my sensors.
I have yet to try to use the Arduino without the ST-Shield.
You know I’ve never actually seen it done, but there really isn’t a reason it couldn’t be. If you can accept and form HTTP messages with the proper headers and json messages then you can send back and forth. You would have to know the IP address of the hub and more importantly the Arduino. Or support SSDP or UDP for discovery.
