Arduino SmartThing Shield Schematic?
Is there a schematic available for the SmartThings shield?
If not, is there a list of pins that are available for my own use? From the example projects I know that pins 2 and 3 are used for communicating with the shield.
It seems that pins 6 and 7 may also be used?
Take at look at the detailed readme on my GitHub repo for my ST_Anything project. Should answer lots of questions and give you a jump start on integrating the Arduino/ThingShield with SmartThings.
To answer you question directly though - Pins 0/1 or 2/3 (switch selectable) are used for serial communications (usually 2/3) and pin 6 is reserved.
Thanks for the reply, but how did you know that pin 6 was reserved?
Here is a schematic sent to me via support, they sent it a s pdf, but pdf’s are not allowed to be uploaded here
so here are 5 jpegs
And here’s the specs for the Ember Chip, I think…
http://cortet.cel.com/docs/default-source/data-sheets/em357_ht_mini_mod_ds.pdf?sfvrsn=25
The reserved Arduino pin appears to be connected to PB5…
Digital I/O
ADC0 - ADC Input 0
TIM2CLK - Timer 2 external clock input
TIM1MSK - Timer 1 external clock mask input
Outstanding finds. Thanks for sharing!
