Hi
I am currently setting up my smart home a bit and came across the Smartthings app, which I really like both visually and in terms of the functions.
I bought some products from Aqara, which I would now like to add to the Smartthings app.
I don’t have a Smartthings Hub or Bridge yet, but only use the app because I can add many other providers there and routines are much better than those in the Google Home app.
As I unfortunately had to find out, the Aqara E1 hub is not compatible with ST, but apparently I have to get a hub from ST. Which one is best for this? A bit budget friendly, because I probably only use it for the Aqara products.
I also noticed that in the ST app, when I select Aqara under Add new devices, some products are not suggested, such as radiator thermostats or the Aqara button. Can these products then also not be added to ST or are they just not 100% supported
Thanks in advance for answers
Kind regards
