Any XYZ sensor compatible with smartthings?
@orangebucket
Can you make recipes (for the rules API) with those values as a trigger?
@joshua_lyon
Can you create SharpTools rules based on those values?
I ask because in the old groovy architecture you could definitely make a smartapp that could use the xyz values of the SmartThings Multisensor: quite a few community members built cubes using that device where they knew which face was up and triggered scenes or hello home actions from that. I think the original was the Mood Cube, but there were eventually about half a dozen with slightly different features.
Here’s one example where the groovy code is still visible (although of course unsupported by the current architecture).
https://github.com/skp19/st_hello_home_cube/blob/master/st_hello_home_cube.groovy
And here’s one of the original project reports. It would be a shame if the new architecture has lost this functionality: there was some really cool stuff based on it. :disappointed_relieved:
A wooden cube that controls lighting [OBSOLETE]
