And also a similar thread that may give you some other ideas.
Iāll look into this one! Nice!!
Iāll share a really cheap solution, get one of those 10 buck 24 hour light timers, set it to turn off and on as close together at 3am. Modem will power cycle nightly for a few minutes offline.
But frankly, if you need to constantly restart the modem, there is something else that is going wrong upstream or in your environment that probably should be dealt with before resorting to rebooting the modem on a schedule.
Agreed⦠just donāt have the TIME to fix it⦠lol! Iāll go with this idea for now⦠but instead of @ 3am⦠Iāll do it at 3 PM when Iām totally sure I wonāt be home⦠Or else the house might go crazy with my coming and going from wifi⦠I went that route for the best experience in location management⦠any other means (in-app location, Life360, smartpresence tags, ā¦) just wonāt doā¦
SmartLighting runs locally right? Set up a rule that when X outlet turns off, turn it on.
**edit - just realize this was already discussed
Just remember they ābreakā by an hour during daylight savings time
I used an arduino with an Ethernet shield and a relay shield to ping Googleās name server and if it fails for 30 seconds, it triggers the relay to turn the cable modem off and then 30 seconds later it turns it back on.
Todd
