I am writing a new smart app to color my landscape using the outdoor osram garden spots.
I could not find a smartapp that would change the color every so often sunset to sunrise…
So far I have it cycle through about 7 colors, only turns on sunset to sunrise and will change color only between these times, OR if you manually turn one or more of the hue lights controlled on.
I have set cycle times of 10 , 15, 30 minutes, 1 hour and 3 hours. so I can use the built in functions of runeveryxxminutes etc. so as not to overload the backend running on fixed times. (check the docs these randomize the time).
I also have a disable/enable option.
I am using the scheduling/cron feature to do this and also schedule turning the hues on at sunset and off at sunrise.
I currently am in development and testing and wanted to see if there was much interest in the app, or if anyone already knew of a smartapp that would do this.
thanks
