Any app that can execute action based on the thermostat's temperature or turn off thermostat based on conditions
  1. When Routine: Away is executed. Turn off the thermostat (compatible Honeywell Thermostat)
  2. If the thermostat’s temperature drop below X. Turn on the thermostat.
  3. Turn on the thermostat when Routine: I am back is executed.
Try this. (there are others available too)
Thanks. I am using a wifi Honeywell thermostat where ST recently started to support. I don’t think this Z-wave Thermostat Manager will work.
Give it a try, if the handler is set up by ST, it should work…
