Another laundry monitor question
Hello, I’m really new with SmartThings and currently exploring its applications.
I have a question about how should I set up a laundry monitor in terms of the hardware.
The threads I found have been years old and new devices has faded and came in since then.
How would you set up a laundry monitor?
Would you use a vibration sensor like ST Multi?
Or would you use an energy monitor plug such as Aeon’s selections or ST outlet?
Or is there an in-wall outlet set up? I assume the GE in-wall outlet can’t do energy monitoring? One I found was the Aeon Micro Energy Switch.
Your advices will be helpful.
I use one like the one below and monitor it with CoRE, a community smart app.
https://www.amazon.com/Aeon-Labs-DSC06106-ZWUS-Z-Wave-Energy/dp/B007UZH7B8
I use a Wemo insight switch. They are only $30 today!
https://www.amazon.com/Insight-Switch-Control-Lights-Appliances/dp/B01DBXNYCS/ref=sr_1_1?ie=UTF8&qid=1480114663&sr=8-1&keywords=wemo+insight
Use this device type for a reliable connection:
You can either use CoRE (see above) or just the Wemo notification.
Thanks for the replies.
I ended up getting two ST outlet and two Wemo switch (the max I can get from amazon).
I’ve yet to close on the house so I’ll have to just grab the units and check the form factor later.
I’ll load up those smartapps/handler.
