I want to turn on lights when one or more of my 4 ring cameras detect motion and I’m away. My question is this: When I identify the cameras I want to use as triggers, how does the automation trigger logic perform?
In other words is it an “AND” or “OR” logic?
For example, does the logic work this way?
“When camera 1, AND camera 2, AND Camera 3, AND camera 4, THEN activate trigger.”
Or does the logic work this way?
“When camera 1, OR camera 2, OR Camera 3, OR camera 4, THEN activate trigger.”
Generally speaking about Boolean expressions (and/or) if you want the light to turn on when ALL cameras detected a movement then it needs to be set to AND, while if you want the lights to turn on when ANY of the four detected movement then it needs to be OR
In the new app If you add more than one condition to the automation If statement, then you have a tab to select it to work in All conditions (AND) or Any condition (OR)
