Has anyone successfully integrated this device into ST? (i.e. outputs are independently controllable in ST)
I see instructions on Aeon Labs’ site that a firmware upgrade is necessary. Is that DTH on their site necessary and works?
Dan
Dan
Anyone? Anyone? Bueller…Bueller…lol.
Seriously though, no one has installed one of these?
Dan
I’m also looking into buying the dual for a couple of applications in my house. Anyone using one successfully? The single switch variant works fine and is detected as an Enerwave switch.
I have an older Monoprice dual in service and it works, but I’d rather use the Aeon.
I just installed ZW140, but am having trouble getting the device setup in smarthings the way I want it to be setup. I chose the ‘Aeon Smartstrip’ as the device Type because the standard type ‘Z-Wave switch’ won’t allow me to control the two switches independent of each other. The Smartstrip type allows you to control both switches independently from the app, but I have not been able to figure out how to get each switch to show up as a separate thing in smarthings. It would help if I wanted to control it via Echo, etc.
Ive just installed one myself and heres what I’ve found.
The firmware update 2.00 is critical
the device works properly after updating, The dev handler linked from the aeotec helpdesk is actually the wrong one, its for a zw139
I’ve contacted aeotec and will provide the link to the code when they get it to me.
the link within the text of zw140 support page is incorrect, however the correct device handler can be found as a text file at the bottom of the page
https://s3.amazonaws.com/cdn.freshdesk.com/data/helpdesk/attachments/production/6059005122/original/Dual%20Nano%20Switch%20without%20Energy%20Reading.txt?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAJ2JSYZ7O3I4JO6DA%2F20180722%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20180722T081025Z&X-Amz-Expires=300&X-Amz-Signature=3d579e7b8369b7a88ba431effb14a44389a492727df6d5cc406818cbcbf6c3c1&X-Amz-SignedHeaders=Host&response-content-type=text%2Fplain
you also must install the metering switch child device handler from Erocm123 as shown on the support page.
Can you link my the where you found this again, the link is gone dead.
I’m having issues with the toggle switches no updating the app.
I found it looking through the aeotec support page for the device, I also informed them at the time so it should most likely be correct on the website now, if you still can’t find it let me know and I’ll copy mine and email it to you.
Douglas Moore
Moore Communications
704-891-3587
Please would you if you don’t mind?
I’ll send pm with my email.
Thank you
Hello,
Can anyone here give me any advice in setting the aeotec dual nano switch up? I am new to the whole home automation thing. I ordered one of these switches so I can operate my ceiling fan and lights. I did not have a neural at the light switch so I couldn’t use a normal smart light switch. Im going to put this one up in the ceiling at the fan. Anyway.
Do i need to do anything to the dual nano switch (zw132-a) other than hook it up and pair it with Smartthings? I hear people talking about “child” handlers and changing configurations or flashing new firmware.
I hope to hook this up so one side of the switch works the ceiling fan and the other worked the fan lights. I also want to still be able to use my 3 way switches. Thanks so much!
In case anyone’s still looking, here’s the support page on adding a Device Handler DTH for the Aeotec Dual Nano Switch on Aeotec’s website. I’m going to try to install one this afternoon and hope to report back how it goes. Note that upgrading the firmware was my first step, so it may be required. I had an old Z-Stick but couldn’t get it to work. A newer Z-Stick Gen 5 worked fine.
And those directions worked well - 1 “main” device and 2 “child” devices appear and you can control one switch for both, or use a child switch for either / or.
