Aeotec Nano Dimmer Features
You mean a device handler which associates the dim down button (S2) with a totally separate zwave device? Or one which supports it more generally? I don’t know if the Fibaro dimmer 2 DTHs work with this dimmer, but if so I would use that and then add something like the one below temporarily, so you can create the zwave association for dim down.
If the Fibaro device doesn’t work with the device then I guess that will need some tweaking. To use the second switch on the Aeotec for a different device I’m pretty sure you can’t do it with a DTH unless you combine with CoRE, better to do it with the zwave associations.
