Using it with Smartthings Aeotec hub. Using Aeotec Multisensor 7 driver.
Settings: 81. LED Enable/Disable - Disable is selected.
I have 2 and both of them brightly flash green every time they detect motion.
So is there no way to turn this off?
SOLVED.
After trying everything I could think of: Excluding and readding, different drivers, holding action button to get it into forced update mode, etc. I finally got the LED turned off.
What I had to do is remove the batteries and plug it in then turn the LED on then off, then switch back to batteries.
