Aeotec Home Energy Meter v1 - Display Amps instead of Watts?
Is there any way to modify the DH of this thing to display Amps instead of Watts? All that’s missing from the calculation is the voltage, so theoretically it would be easy to do? I know nothing about coding, so pardon my ignorance.
I’m using this DH: jscgs350 : My Aeon Home Energy Monitor Gen1
Can this be done? or How can I modify the code myself to do this?
Aeotec has some documentation on the HEM1 (pdf). According to their documentation, they do not report voltage or current. Heck, they don’t even measure the voltage, they take a fixed value configured in param 1 as 120V or 240V - I’m assuming you’re in the US, so simply dividing the reported wattage by 120 should give you the amperage. Of course, since it’s dealing with AC currents, the proper term is VA (volt-ampere), not W (watt). The DTH (link here) can be modified to show amperes, based on the findings above.
I haven’t tested this, but it may work:
 *	Aeon HEM1
 *	Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *	in compliance with the License. You may obtain a copy of the License at:
 *		http://www.apache.org/licenses/LICENSE-2.0
 *	Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *	on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *	for the specific language governing permissions and limitations under the License.
 *	Aeon Home Energy Meter gen-1 (US)
 *	Updates:
 *	02-15-2016 : Removed posting to the Activity Feed in the phone app and event log.
 *	02-17-2016 : Fixed preferences for kWh cost from string to number.
 *	02-20-2016 : Enabled battery reporting (parameter 103, value 1), and documented the parameters better.
 *	02-21-2016 : Made certain configuration parameters changeable via device preferences instead of having to tweak code all the time.
 *	02-22-2016 : Fixed kWh cost entry in Preferences not allowing decimals.
 *	02-27-2016 : Changed date formats to be MM-dd-yyyy h:mm a.
 *	02-29-2016 : Changed reportType variable from 0 to 1.
 *	03-11-2016 : Due to ST's v2.1.0 app totally hosing up SECONDARY_CONTROL, implemented a workaround to display that info in a separate tile.
 *	03-19-2016 : Added clarity for preferences.
 *	03-21-2016 : Fixed issue when resetting energy would also reset watts.
 *	03-25-2016 : Removed the \n from the two tiles for resetting watts and energy due to rendering issues on iOS
 *	07-07-2016 : Check for wildly large watts value coming from the HEM and do not process them.  Firmware updates should have resolved this.
 *	08-10-2016 : Check for 0 or negative watts value coming from the HEM and do not process them.  Firmware updates should have resolved this.
 *	08-21-2016 : Created separate tiles to reset min and max instead of having a single tile for both values.  Changed many tiles to different sizes.
 *	08-27-2016 : Modified the device handler for my liking, primarly for looks and feel.
 *	09-16-2016 : During the check for 0 or negative values, use the last power value (state.powerValue) instead of just a hard coded value.
 *	10-17-2016 : Cleaned up code.
 *	10-19-2016 : Provided comments in the code for iOS users to edit so that the rendering of text for certain tiles to work right.	 Changed default icon.
 *	10-19-2016 : Added a new parameter in Preferences so that a user can specify the high limit for a watts value instead of hard coding a value.  Related to the change on 7-7-2016.
 *	11-22-2016 : Added resetMeter section that calls the other resets (min, max, energy/cost).	This is for a SmartApp that resets the meter automatically at the 1st day of month.
 *	01-08-2017 : Added parameter 12 and set it to 1.  Accumulates kWh energy when Battery Powered.
 *	01-08-2017 : Cleaned up code in the resetMeter section.
 *	01-08-2017 : Added code for Health Check capabilities/functions, and cleaned up code in the resetMeter section.
 *	01-18-2017 : Removed code no longer needed, and added another parameter in Preference to enable or disable the display of values in the Recently tab and device's event log (not Live Logs).  Enabling may be required for some SmartApps.
 *	01-20-2017 : Removed the check for 0w, but still don't allow negative values.  Also removed all rounding, which now displays 3 positions right of the decimal.
 *	02-11-2017 : Removed commands no longer needed.	 Documented what each attribute is used for.  Put battery info into the main tile instead of a separate tile.
 *	02-12-2017 : Combined the battery and no-battery version into a single DTH, cleaned up code, and general improvements.
 *	02-13-2017 : Cleaned up code for battery message being displayed. If someone decides to display battery % while not having batteries installed Health Check will catch that and push low battery notifications until the user disables the display.
 *	03-11-2017 : Changed from valueTile to standardTile for a few tiles since ST's mobile app v2.3.x changed something between the two.
 *	03-26-2017 : Added a new device Preference that allows for selecting how many decimal positions should be used to display for WATTS and kWh.  What's stored for the actual meter reading that's seen in the IDE for Power, and what's sent to SmartApps, has not changed.
 *	03-29-2017 : Made changes to account for ST v2.3.1 bugs with text rendering.
 *	04-28-2017 : Cleaned up code, and some formatting/tile layout changes for my liking.
 *	05-18-2017 : Changed valueTile to standardTile to resolve font/rendering issues.
 *	05-28-2017 : Sometimes the HEM will send a super low reading, like 0.04672386; which in that case the decimal position setting would not get applied if you used 3.	 That's been fixed.
 *  05-30-2017 : Thanks to @barkis for the following changes: fixed number of decimal points display on iPhone app; fixed problem with kVAh units display; changed refresh() to immediately update values; reworked decimal place selection to remove 'else' branch that never executes; removed some un-needed temporary variables; code cleanup (trailing whitespace/converted leading spaces to tabs to shrink file size)
 *  06-05-2017 : Some tweaks for the 2.4.0 release of the mobile app.
 *  06-12-2017 : Updated code to make sure kWh or kVAh readings from the reader are larger that the previous reading.  There should never be a smaller reading from the previous reading.
 *  06-14-2017 : Updated to fix battery reports showing up in the Recently tab when they shouldn't.
 *  06-19-2017 : Cleaned up code in the resetkwh() section.
 *  06-29-2017 : Rolled back change from 6-12-2017 until I find a better method of checking.
 *  09-27-2017 : Changed tile format for device min/max history to look like my Aeon and Zooz DTH's.
 *  09-28-2017 : Changed history tile from "standard" to "value", and reduced the number of dashes so it works better for iOS.
 *  10-04-2017 : Fixed reset issues with energy/kWh not resetting properly.  (more of a workaround for now)
 *  10-07-2017 : Fixed code for battery reports still going to the Recently tab in the mobile app even though the option not to send messages was enabled.
 *  10-26-2017 : Added 2 new attributes to capture kWh and cost data before they're reset in case someone needs to refer back to them for any reason.  These can be seen in the IDE and in the Recently Tab in the mobile app.
metadata {
	definition (name: "My Aeon Home Energy Monitor Gen1", namespace: "jscgs350", author: "jscgs350")
		capability "Energy Meter"
		capability "Power Meter"
		capability "Configuration"
		capability "Sensor"
		capability "Refresh"
		capability "Polling"
		capability "Battery"
//		capability "Health Check"
		attribute "currentKWH", "string"		// Used to show current kWh since last reset
		attribute "currentWATTS", "string"		// Used to show current watts being used on the main tile
		attribute "currentAmperes", "string"	// Used to show current watts being used on the main tile
		attribute "minWATTS", "string"			// Used to store/display minimum watts used since last reset
		attribute "maxWATTS", "string"			// Used to store/display maximum watts used since last reset
		attribute "resetMessage", "string"		// Used for messages of what was reset (min, max, energy, or all values)
		attribute "kwhCosts", "string"			// Used to show energy costs since last reset
		attribute "batteryStatus", "string"
        attribute "kWhLastReset", "number"
        attribute "CostLastReset", "number"
        attribute "current", "number"
		command "resetkwh"
		command "resetmin"
		command "resetmax"
		command "resetMeter"
		fingerprint deviceId: "0x2101", inClusters: " 0x70,0x31,0x72,0x86,0x32,0x80,0x85,0x60"
	// tile definitions
	tiles(scale: 2) {
		multiAttributeTile(name:"currentWATTS", type: "generic", width: 6, height: 4, decoration: "flat"){
			tileAttribute ("device.currentWATTS", key: "PRIMARY_CONTROL") {
				attributeState "default", label: '${currentValue}W', icon: "https://raw.githubusercontent.com/constjs/jcdevhandlers/master/img/device-activity-tile@2x.png", backgroundColor: "#79b821"
			tileAttribute ("device.batteryStatus", key: "SECONDARY_CONTROL") {
				attributeState "batteryStatus", label:'${currentValue}', icon:"https://raw.githubusercontent.com/constjs/jcdevhandlers/master/img/Battery-Charge-icon.png"
		standardTile("iconTile", "iconTile", inactiveLabel: false, width: 1, height: 1) {
			state "default", icon:"https://raw.githubusercontent.com/constjs/jcdevhandlers/master/img/device-activity-tile@2x.png"
		valueTile("statusText", "statusText", inactiveLabel: false, decoration: "flat", width: 5, height: 1) {
			state "statusText", label:'${currentValue}', backgroundColor:"#ffffff"
		valueTile("resetMessage", "device.resetMessage", width: 5, height: 1, inactiveLabel: false, decoration: "flat") {
			state("default", label: '${currentValue}', backgroundColor:"#ffffff")
		valueTile("currentKWH", "device.currentKWH", width: 3, height: 1, inactiveLabel: false, decoration: "flat") {
			state("default", action: "refresh", label: '${currentValue}', backgroundColor:"#ffffff")
		valueTile("kwhCosts", "device.kwhCosts", width: 3, height: 1, inactiveLabel: false, decoration: "flat") {
			state("default", label: 'Cost ${currentValue}', backgroundColor:"#ffffff")
		standardTile("resetmin", "device.resetmin", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
			state "default", label:'Reset Min', action:"resetmin", icon:"st.secondary.refresh-icon"
		standardTile("resetmax", "device.resetmax", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
			state "default", label:'Reset Max', action:"resetmax", icon:"st.secondary.refresh-icon"
		standardTile("resetkwh", "device.resetkwh", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
			state "default", label:'Reset Energy', action:"resetkwh", icon:"st.secondary.refresh-icon"
		standardTile("refresh", "device.refresh", width: 3, height: 2, inactiveLabel: false, decoration: "flat") {
			state "default", label:'Refresh', action:"refresh", icon:"st.secondary.refresh-icon"
		standardTile("configure", "device.configure", width: 3, height: 2, inactiveLabel: false, decoration: "flat") {
			state "configure", label:'', action:"configure", icon:"st.secondary.configure"
		valueTile("history", "device.history", decoration:"flat",width: 6, height: 2) {
			state "history", label:'${currentValue}'
		main (["currentWATTS"])
		details(["currentWATTS", "currentKWH", "kwhCosts", "currentAmperes", "history", "resetmin", "resetmax", "resetkwh", "refresh", "configure"])
	preferences {
		input "displayEvents", "boolean", title: "Display all power and energy events in the Recently tab and the device's event log?",	defaultValue: false, required: false, displayDuringSetup: true
		input "displayBatteryLevel", "boolean", title: "Display battery level on main tile and Recently tab?", defaultValue: true, required: false, displayDuringSetup: true
        input "kWhCost", "string", title: "Enter your cost per kWh (or just use the default, or use 0 to not calculate):", defaultValue: 0.16, required: false, displayDuringSetup: true
		input "wattsLimit", "number", title: "Sometimes the HEM will send a wildly large watts value. What limit should be in place so that it's not processed? (in watts)", defaultValue: 20000, required: false, displayDuringSetup: true
		input "reportType", "number", title: "ReportType: Send watt/kWh data on a time interval (0), or on a change in wattage (1)? Enter a 0 or 1:", defaultValue: 1, range: "0..1", required: false, displayDuringSetup: true
		input "wattsChanged", "number", title: "For ReportType = 1, Don't send unless watts have changed by this many watts: (range 0 - 32,000W)", defaultValue: 50, range: "0..32000", required: false, displayDuringSetup: true
		input "wattsPercent", "number", title: "For ReportType = 1, Don't send unless watts have changed by this percent: (range 0 - 99%)", defaultValue: 10, range: "0..99", required: false, displayDuringSetup: true
		input "secondsWatts", "number", title: "For ReportType = 0, Send Watts data every how many seconds? (range 0 - 65,000 seconds)", defaultValue: 15, range: "0..65000", required: false, displayDuringSetup: true
		input "secondsKwh", "number", title: "For ReportType = 0, Send kWh data every how many seconds? (range 0 - 65,000 seconds)", defaultValue: 60, range: "0..65000", required: false, displayDuringSetup: true
		input "secondsBattery", "number", title: "If the HEM has batteries installed, send battery data every how many seconds? (range 0 - 65,000 seconds)", defaultValue: 900, range: "0..65000", required: false, displayDuringSetup: true
		input "decimalPositions", "number", title: "How many decimal positions do you want watts AND kWh to display? (range 0 - 3)", defaultValue: 3, range: "0..3", required: false, displayDuringSetup: true
def updated() {
	// Device-Watch simply pings if no device events received for 32min(checkInterval)
	sendEvent(name: "checkInterval", value: 2 * 15 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
	state.displayDisabled = ("true" == displayEvents)
	state.displayBattery = ("true" == displayBatteryLevel)
	log.debug "updated (kWhCost: ${kWhCost}, wattsLimit: ${wattsLimit}, reportType: ${reportType}, wattsChanged: ${wattsChanged}, wattsPercent: ${wattsPercent}, secondsWatts: ${secondsWatts}, secondsKwh: ${secondsKwh}, secondsBattery: ${secondsBattery}, decimalPositions: ${decimalPositions})"
	response(configure())
//	log.debug "Parse received ${description}"
	def result = null
	def cmd = zwave.parse(description, [0x31: 1, 0x32: 1, 0x60: 3, 0x80: 1])
//	log.debug "Parse returned ${cmd}"
	if (cmd) {
		result = createEvent(zwaveEvent(cmd))
//	if (result) log.debug "Result returned ${result}"
	if (state.displayBattery) {
		def batteryStatusmsg = "USB power, batteries at ${device.currentState('battery')?.value}%"
		sendEvent(name: "batteryStatus", value: batteryStatusmsg, displayed: false)
	} else {
		def batteryStatusmsg = "USB power"
	return result
def zwaveEvent(physicalgraph.zwave.commands.meterv1.MeterReport cmd) {
	def dispValue
	def newValue
	def timeString = new Date().format("MM-dd-yy h:mm a", location.timeZone)
	if (cmd.meterType == 33) {
		if (cmd.scale == 0) {
			newValue = cmd.scaledMeterValue
//            log.debug "newValue is ${newValue} and prevValue is ${state.energyValue}"
			if (newValue != state.energyValue) {
				if (decimalPositions == 2) {
					dispValue = String.format("%3.2f",newValue)
				} else if (decimalPositions == 1) {
					dispValue = String.format("%3.1f",newValue)
				} else if (decimalPositions == 0) {
					dispValue = Math.round(cmd.scaledMeterValue)
				} else {
					dispValue = String.format("%3.3f",newValue)		// default
				dispValue += " kWh"
				sendEvent(name: "currentKWH", value: dispValue as String, unit: "", displayed: false)
				state.energyValue = newValue
				BigDecimal costDecimal = newValue * (kWhCost as BigDecimal)
				def costDisplay = "\$"
				costDisplay += String.format("%3.2f",costDecimal)
				sendEvent(name: "kwhCosts", value: costDisplay as String, unit: "", displayed: false)
				if (state.displayDisabled) {
					[name: "energy", value: newValue, unit: "kWh", displayed: true]
				} else {
					[name: "energy", value: newValue, unit: "kWh", displayed: false]
		} else if (cmd.scale == 1) {
				dispValue = newValue + " kVAh"
					[name: "energy", value: newValue, unit: "kVAh", displayed: true]
				} else {
					[name: "energy", value: newValue, unit: "kVAh", displayed: false]
		else if (cmd.scale==2) {
			newValue = cmd.scaledMeterValue								// Remove all rounding
			if (newValue < 0) {newValue = state.powerValue}				// Don't want to see negative numbers as a valid minimum value (something isn't right with the meter) so use the last known good meter reading
			if (newValue < wattsLimit) {								// don't handle any wildly large readings due to firmware issues
				if (newValue != state.powerValue) {						// Only process a meter reading if it isn't the same as the last one
					} else {
					if (newValue < state.powerLow) {
						def dispLowValue = dispValue+"w on "+timeString
						sendEvent(name: "minWATTS", value: dispLowValue as String, unit: "", displayed: false)
						state.powerLow = newValue
                        def historyDisp = ""
					    historyDisp = "Minimum/Maximum Readings as of ${timeString}\n------------------------------------------------------\nPower Low : ${device.currentState('minWATTS')?.value}\nPower High : ${device.currentState('maxWATTS')?.value}\nMessages : ${device.currentState('resetMessage')?.value}"
					    sendEvent(name: "history", value: historyDisp, displayed: false)
					if (newValue > state.powerHigh) {
						def dispHighValue = dispValue+"w on "+timeString
						sendEvent(name: "maxWATTS", value: dispHighValue as String, unit: "", displayed: false)
						state.powerHigh = newValue
					sendEvent(name: "currentWATTS", value: dispValue as String, unit: "", displayed: false)
						dispValue = String.format("%3.2f",newValue / 120.0)
						dispValue = String.format("%3.1f",newValue / 120.0)
						dispValue = Math.round(cmd.scaledMeterValue / 120.0)
					} else {
						dispValue = String.format("%3.3f",newValue / 120.0)		// default
                    sendEvent(name: "currentAmperes", value: dispValue as String, unit: "", displayed: false)
					state.powerValue = newValue
                        	[name: "power", value: newValue, unit: "W", displayed: true],
                            [name: "current", value: newValue / 120.0, unit: "A", displayed: true]
					} else {
                        	[name: "power", value: newValue, unit: "W", displayed: false],
                            [name: "current", value: newValue / 120.0, unit: "A", displayed: false]
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
		def map = [:]
		map.name = "battery"
		map.unit = "%"
        map.displayed = true
		if (cmd.batteryLevel == 0xFF) { // low battery message from device
			map.value = 1
			map.isStateChange = true
		} else {
			map.value = cmd.batteryLevel
	sendEvent(name: "battery", value: map.value as String, displayed: true)
	return map
	} else {
		def map = [:]
		map.unit = "%"
        map.value = 99
        map.displayed = false
        sendEvent(name: "battery", value: map.value as String, displayed: false)
		return map
	// Handles all Z-Wave commands we aren't interested in
	log.debug "Unhandled event ${cmd}"
def refresh() {
	log.debug "Refreshed ${device.name}"
	state.energyValue = -1		// force tile update
	state.powerValue = -1
	delayBetween([
		zwave.meterV2.meterGet(scale: 0).format(),
		zwave.meterV2.meterGet(scale: 2).format()
def poll() {
	refresh()
// PING is used by Device-Watch in attempt to reach the Device
def ping() {
	refresh()
def resetkwh() {
	log.debug "${device.name} reset kWh/Cost values"
    def resetDisp = ""
    resetDisp = "kWh value at time of last reset was ${device.currentState('currentKWH')?.value}"
    sendEvent(name: "kWhLastReset", value: resetDisp, displayed: true)
    resetDisp = "Costs at time of last reset was ${device.currentState('kwhCosts')?.value}"
    sendEvent(name: "CostLastReset", value: resetDisp, displayed: true)
	sendEvent(name: "resetMessage", value: "Energy Data (kWh/Cost) Reset On:\n"+timeString, unit: "", displayed: true)
	sendEvent(name: "currentKWH", value: "", unit: "", displayed: false)
	sendEvent(name: "kwhCosts", value: "", unit: "", displayed: false)
    state.energyValue = 0
	def cmd = delayBetween( [
		zwave.meterV2.meterReset().format(),
	cmd
def resetmin() {
	log.debug "${device.name} reset minimum watts value"
	state.powerLow = 99999
	sendEvent(name: "resetMessage", value: "Watts Data Minimum Value Reset On:\n"+timeString, unit: "")
	sendEvent(name: "minWATTS", value: "", unit: "", displayed: false)
	cmd
def resetmax() {
	log.debug "${device.name} reset maximum watts value"
	state.powerHigh = 0
	sendEvent(name: "resetMessage", value: "Watts Data Maximum Value Reset On:\n"+timeString, unit: "")
	sendEvent(name: "maxWATTS", value: "", unit: "", displayed: false)
	cmd
def resetMeter() {
	log.debug "Resetting all home energy meter values..."
    def resetDisp = ""
	state.powerHigh = 0
	sendEvent(name: "kwhCosts", value: "Cost\n--", unit: "", displayed: false)
	sendEvent(name: "resetMessage", value: "HEM was reset on "+timeString, unit: "", displayed: true)
	cmd
def configure() {
	log.debug "${device.name} configuring..."
	def cmd = delayBetween([
        // Perform a complete factory reset. Use this all by itself and comment out all others below.
        // Once reset, comment this line out and uncomment the others to go back to normal
//    	zwave.configurationV1.configurationSet(parameterNumber: 255, size: 4, scaledConfigurationValue: 1).format()
        // Accumulate kWh energy when Battery Powered. By default this is disabled to assist saving battery power. (0 == disable, 1 == enable)
        zwave.configurationV1.configurationSet(parameterNumber: 12, size: 1, scaledConfigurationValue: 1).format(),
        // Send data based on a time interval (0), or based on a change in wattage (1).	 0 is default and enables parameters 111, 112, and 113. 1 enables parameters 4 and 8.
        zwave.configurationV1.configurationSet(parameterNumber: 3, size: 1, scaledConfigurationValue: reportType).format(),
        // If parameter 3 is 1, don't send unless watts have changed by 50 <default> for the whole device.
        zwave.configurationV1.configurationSet(parameterNumber: 4, size: 2, scaledConfigurationValue: wattsChanged).format(),
        // If parameter 3 is 1, don't send unless watts have changed by 10% <default> for the whole device.
        zwave.configurationV1.configurationSet(parameterNumber: 8, size: 1, scaledConfigurationValue: wattsPercent).format(),
        // Defines the type of report sent for Reporting Group 1 for the whole device.	1->Battery Report, 4->Meter Report for Watt, 8->Meter Report for kWh
        zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 4).format(), //watts
        // If parameter 3 is 0, report every XX Seconds (for Watts) for Reporting Group 1 for the whole device.
        zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: secondsWatts).format(),
        // Defines the type of report sent for Reporting Group 2 for the whole device.	1->Battery Report, 4->Meter Report for Watt, 8->Meter Report for kWh
        zwave.configurationV1.configurationSet(parameterNumber: 102, size: 4, scaledConfigurationValue: 8).format(), //kWh
        // If parameter 3 is 0, report every XX seconds (for kWh) for Reporting Group 2 for the whole device.
        zwave.configurationV1.configurationSet(parameterNumber: 112, size: 4, scaledConfigurationValue: secondsKwh).format(),
        // Defines the type of report sent for Reporting Group 3 for the whole device.	1->Battery Report, 4->Meter Report for Watt, 8->Meter Report for kWh
        zwave.configurationV1.configurationSet(parameterNumber: 103, size: 4, scaledConfigurationValue: 1).format(), //battery
        // If parameter 3 is 0, report every XX seconds (for battery) for Reporting Group 2 for the whole device.
        zwave.configurationV1.configurationSet(parameterNumber: 113, size: 4, scaledConfigurationValue: secondsBattery).format()
	cmd
So I took your code and showed it to a co-worker who just so happens to know a little about writing code. He helped me get it to display amps vs watts, but leave the “currentWATTS” part alone so the kWh stuff still works…at least I hope…lol
I added a line to the bottom of the “changelog” detailing what was done and how to revert it.
Thank you!
Here is what I have:
Summary
>  *	Aeon HEM1
>  *	Updates:
>  *  6/29/2018  : Modified to calculate and display Amperes in the main display vs Watts, based on 240V. To revert, swap out "currentAmperes" with "currentWATTS" on lines 99, 100, and 141. Also change "A" to "W" on line 101.
> metadata {
> 	definition (name: "HEM - Amperes", namespace: "jscgs350", author: "jscgs350")
> 		capability "Sensor"
> 		attribute "currentAmperes", "string"	// Used to show current Amps being used on the main tile
> 		command "resetkwh"
> 		command "resetmin"
> 		command "resetmax"
> 	// tile definitions
> 	tiles(scale: 2) {
> 		multiAttributeTile(name:"currentAmperes", type: "generic", width: 6, height: 4, decoration: "flat"){
> 			tileAttribute ("device.currentAmperes", key: "PRIMARY_CONTROL") {
> 				attributeState "default", label: '${currentValue}A', icon: "https://raw.githubusercontent.com/constjs/jcdevhandlers/master/img/device-activity-tile@2x.png", backgroundColor: "#79b821"
> 		main (["currentAmperes"])
> 	preferences {
> def updated() {
> 	def result = null
> 	if (cmd) {
> 	} else {
> 	return result
> 	def dispValue
> 	def newValue
> 				} else {
> 				dispValue += " kWh"
> 				} else {
> 				} else {
> 					} else {
> 						dispValue = String.format("%3.2f",newValue / 240.0)
> 						dispValue = String.format("%3.1f",newValue / 240.0)
> 						dispValue = Math.round(cmd.scaledMeterValue / 240.0)
> 					} else {
> 						dispValue = String.format("%3.3f",newValue / 240.0)		// default
>                         	[name: "power", value: newValue, unit: "A", displayed: true],
>                             [name: "current", value: newValue / 240.0, unit: "A", displayed: true]
> 					} else {
>                         	[name: "power", value: newValue, unit: "A", displayed: false],
>                             [name: "current", value: newValue / 240.0, unit: "A", displayed: false]
> 		def map = [:]
> 		map.unit = "%"
> 			map.value = 1
> 		} else {
> 	return map
> 	} else {
> 		def map = [:]
> 		map.unit = "%"
>         map.value = 99
> 		return map
> def refresh() {
> 	delayBetween([
> def poll() {
> 	refresh()
> def ping() {
> 	refresh()
> def resetkwh() {
>     def resetDisp = ""
> 	cmd
> def resetmin() {
> 	cmd
> def resetmax() {
> 	state.powerHigh = 0
> 	cmd
> def resetMeter() {
>     def resetDisp = ""
> 	state.powerHigh = 0
> 	cmd
> def configure() {
> 	cmd
Awesome, so you have amps displayed now?
Sure do! I mainly wanted this so I can see how many amps my woodworking equipment draws on my electrical system. So it’s very low because there’s not much running out there right now. Here’s how it looks:
Thats great Bryan can you upload the DH?
It’s in my post above. Click summary and you should be able to copy/paste the code.
Thanks! Looked right past that.
Getting an odd response when i try to save or publish it
org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed:
script_dth_metadata_633b8886_9f6d_4cc0_8dc5_9f64eb4c1552: 65: unexpected token: > @ line 65, column 1.
metadata {
1 error
Are you trying to add it as a Device or Device Handler? This should be added as a device handler.
I was editing the one I already had. Once I removed all of the "> " values from the entire text it worked.
Bryank930,
The waveform should be a sine wave if we are talking about alternating current.
The one in your post looks more like part of a heartbeat.
Just sayin’
Glad you got it working :slight_smile:
