Aeon Labs Recessed Sensor Gen 5 won't connect
Has anyone had issues with this item not connecting and if so did they find a fix.
Basically I have followed the instructions and tried to have it join the network both ways.
I open up the app hit either the connect new things or the specific and then press the tab on the sensor. The light goes on for 5 seconds and circle on the app spins and spins and spins but nothing connects and joins. The sensor is only inches away from the hub.
Have you given these steps a shot?
Tried that too now and all I get is spinning, spinning, spinning on the General Device Exclusion screen
You might want to try support@smartthings.com. If it’s not excluding then the device isn’t communicating with the hub at all. You’ll need to get that first step to be successful or it won’t pair.
edit: also try rebooting your hub
Dumb question @Tyler does rebooting the hub mean I have to re add everything.
Nope, just remove power (and batteries if you have them in) and wait a few minutes.
Okay thanks I will try that next now.
Done that and still nothing. Any other suggestions?
@Tyler managed to use a couple of the steps you listed and got the thing on line and working.
Thanks for the help. I promise not to bug you about the Arlo cameras for at least a week. :grin:
