I recently added an Aeon Labs Minimote and I am having what appear to be key bounce problems. I press a key once, and my SmartThings hub records multiple keypress events. This causes whatever action I’ve linked to that button to trigger multiple times.
Does anyone else have this problem? Any solutions?
Once I use the Smartapp Button Controller to setup the MiniMote it seems to work, however I can’t find a way to get back and change any of the settings. Am I missing something?
bamarayne
107
Yep…
Tayyip on the three horizontal lines in the top right corner of your screen. (That’s called the hamburger… Cause it’s fun, that’s why). Now tap on smartapps and go down to the one you need.
BTW, I highly recommend marking each minimote on the back with a number or letter or colored dot sticker so you can tell which is which if they wander from room to room.
Then you can just name the button controller smartapp instance to match the minimote label.
