I’m using an AEOTEC Multisensor in a routine to get room temperature and turn on/off my AC. However when I try to enter the temperature condition it only allows between -20 and 50. I’d like to have the AC turn on when the temp gets above 75, not when it gets above 50. The device is shown in Fahrenheit but it seems like the routine rule has some sort of Celsius max range. How do I enter a number above 50?
Did you ever find a solution to this?
Yes but it’s haphazard to get it to work. It seems that some ways to enter the trigger puts it in F mode and some ways put it in C mode for data entry. I just kept deleting and trying different ways to set the limits and sometimes it will randomly allow Fahrenheit ranges. It works GREAT once set. So much more comfortable than a regular thermostat because the sensor is right where I’m sitting.
