2Gig CT100 Programming
For anyone using a CT100 thermostat, I would like to know if you can program it via Smartthings? I am looking to replace my current 5-1-1 programmable thermostat with a Z-wave thermostat, but want to make sure that there is a way to program the unit via Smartthings. With my current 5-1-1 thermostat (non-z wave & non-wifi), i have it set so that during the day when I am at work, the temperature changes, then returns to a normal temperature before I come home for the evening.
I can see on the 2Gig website that the unit can be controlled, just not sure if this can be done by SmartThings? Or would a new app have to be rewritten to control the CT100.
Thanks in advance.
Mike
+1
Yes, I have one. Works great with ST.
Yes, got one a few days ago, and so far, it works well when controlling the thermostat manually. However, I’m not sure how the Cozy Setting SmartApp works. If the CT100 is turned off, the temperatures set in the app does not do anything to activate the thermostat when my mode is set to Home. Is this how the app is supposed to work or do I have to set the thermostat to AUTO so that the thermostat engages when I set the mode the Home?
