And this thread about using the clamps separately:
Lots of info here, linking to a post where Mike Maxwell provides a link to his DTH
Link to the modified version of Mike Maxwell’s DTH that I created…a few posts lower I have some updated webCore pistons I use for washer/dryer notifications including a looping reminder that makes use of door sensors on the washer and dryer.
@Danabw I am having lots of problems with using this in webcore. Is there a way to change this DTH around to use it for energy alerts on each clamp?
In webcore, it’s not giving me a notification that it’s done but I can simulate a dryer wattage change to 0 with another piston and it gives me the notification.
than not sure what you are asking… it does separate the clamps… and turns on a switch when either washer or dryer is done… you should be checking for that switch in the smartapp not the energy
I’ve been trying a few options but had no luck. Reading several of the threads I may not be alone.
Using the device handler mentioned I can get we webcore to log output of individual sensors but for some reason I can’t get it to alert on them as if they were separate.
Does anyone have any recommendations? My washer and dryer “idle” at 6watts when off and don’t drop below 15 when running so I think it’s stable and predictable enough
