1-4 gang touch panel Zigbee switch from LUMI (Vietnam)
Hi, does anyone use this switch for smartthings, this type have 4 gang max on 1 touch panel.
It work well with their own hub. It pair successful with SmartThings as unknown device. I change device type to zigbee switch or use Device Handler Zigbee switch template, It can controlled by smarthings but the 1st switch on touch panel only. I think the default Zigbee switch Device handler was code for single switch, we need to custom devices handler to use with multi channel switch.
Anyone have solution to use it with ST? Thanks!
Here is the device log for each button press (on/off) on my 3 button panel.
7f4aae96-a6b8-4f87-ad20-a13f12884bff ‎8‎:‎46‎:‎10‎ ‎PM: debug description is catchall: 0104 0006 05 01 0140 00 D6F8 00 00 0000 01 01 0000001000
7f4aae96-a6b8-4f87-ad20-a13f12884bff ‎8‎:‎46‎:‎02‎ ‎PM: debug description is catchall: 0104 0006 05 01 0140 00 D6F8 00 00 0000 01 01 0000001001
7f4aae96-a6b8-4f87-ad20-a13f12884bff ‎8‎:‎46‎:‎00‎ ‎PM: debug description is catchall: 0104 0006 03 01 0140 00 D6F8 00 00 0000 01 01 0000001000
7f4aae96-a6b8-4f87-ad20-a13f12884bff ‎8‎:‎45‎:‎57‎ ‎PM: debug description is catchall: 0104 0006 03 01 0140 00 D6F8 00 00 0000 01 01 0000001001
7f4aae96-a6b8-4f87-ad20-a13f12884bff ‎8‎:‎45‎:‎53‎ ‎PM: debug description is catchall: 0104 0006 01 01 0140 00 D6F8 00 00 0000 01 01 0000001000
7f4aae96-a6b8-4f87-ad20-a13f12884bff ‎8‎:‎45‎:‎49‎ ‎PM: debug description is catchall: 0104 0006 01 01 0140 00 D6F8 00 00 0000 01 01 0000001001
Hi, where do you get the switch?
Do you mind share the link please?
They sell local in Vietnam about 50-60usd for 1 to 4 gang with 2 year warranty, maximum 5A current, thay also have 16A current max. type. It has look good, good build quality and touch sensitive.
It will be perfect if work with smartthings.
Their website:
they also sell global here:
https://www.alibaba.com/product-detail/4-Gang-UK-Standard-Zigbee-Touch_50020603984.html
If your live in Australia, you can buy here:
https://liteautomation.com.au/collections/all
I have device handler and smartapp code for lumi switch 4 buttons. I think, with minor tweak you can make it work with other Lumi model. The problem is, either device handler or smartapp code is not good, if you double tap on a button, it will keep turn on and off until you cut the power line or uninstall the smartapp.
If you need it I can share its code and if you can fix it, please share with me.
LV
@Vu Long: Can you share Device Handler and Smartapp code to me. I am also interested in this device.
@lohisake. Please share it for me too. Thank you so much.
Here is handler of Lumi 3 gangs. But it is multichanel switch. I don’t know how to independent it to 3 switchs. Anyone please check and have solution?
Mời bạn tham dự Chủ đề Tiếng VIệt
@lohisake may you share this driver please.
