Zwave Power Strip from AEON
@jwu hi again
Device handler below is working for me as for as ON/OF of individual relays is concerned. Tiles for the individual relay (switch2 for relay1) changes colour too. Value tiles for power and energy update when I hit refresh.
Here is what I need to fix/incorporate.
A) I want to be able to update state (ON/OF) of all tiles when any one tile changes state.
B) I also want to update all power and energy tiles when A happens
can you help? I tried calling refresh() in on1() but then only refresh gets called, first part of the code does not trigger the switch.
def on1() {
	delayBetween([
		zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:37, command:1, parameter:[255]).format(),
		zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:37, command:2).format()
refresh()
Complete device handler is as under:
 *  Based on Aeon Smartstrip
 *  Devive handler for TKB TZ04 dual Realy insert
 *  By using BINARY_SWITCH_SET Command of Multi Channel Command Class Encapsulateion Command,
 *  you can switch both Relay1 and Relay2 ON/OFF by setting endpoint to 1 or switch Relay1 ON/OFF
 *  by setting endpoint to 2 or switch Relay1 ON/OFF by setting endpoint to 3
 *  Status of Endpoint 1 returns ON when either relay 1 or 2 is ON or both or ON
 *  Device is capable of metering (combined when endpoint is set to 1) and individually when set to 2 or 3
 *  TODO
 *  Standard TILES work an relays cn be switched on or off by setting endpoints 1-3
 *  However value tiles only get updated after hitting refresh
 // for the UI
metadata {
	// Automatically generated. Make future change here.
	definition (name: "Aeon Smart Strip", author: "jjhamb@yahoo.com") {
		capability "Energy Meter"
		capability "Refresh"
		capability "Power Meter"
		capability "Switch"
		capability "Configuration"
		capability "Polling"
		attribute "power1", "string"
		attribute "power2", "string"
		attribute "power3", "string"
		attribute "energy1", "string"
		attribute "energy2", "string"
		attribute "energy3", "string"
		attribute "switch1", "string"
		attribute "switch2", "string"
		attribute "switch3", "string"
		command "on1"
		command "off1"
		command "on2"
		command "off2"
		command "on3"
		command "off3"
		command "testA"
		command "testB"
	simulator {
		// TODO: define status and reply messages here
	tiles {
        valueTile("power", "device.power", decoration: "flat") {
			state "default", label:'${currentValue} W'
		valueTile("energy", "device.energy", decoration: "flat") {
			state "default", label:'${currentValue} kWh'
		standardTile("switch1", "device.switch1",canChangeIcon: true) {
                        state "on", label: "switch1", action: "off1", icon: "st.switches.switch.on", backgroundColor: "#79b821"
                        state "off", label: "switch1", action: "on1", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
        standardTile("switch2", "device.switch2",canChangeIcon: true) {
                        state "on", label: "switch2", action: "off2", icon: "st.switches.switch.on", backgroundColor: "#79b821"
                        state "off", label: "switch2", action: "on2", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
        standardTile("switch3", "device.switch3",canChangeIcon: true) {
                        state "on", label: "switch3", action: "off3", icon: "st.switches.switch.on", backgroundColor: "#79b821"
                        state "off", label: "switch3", action:"on3", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
        standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
                        state "default", label:"", action:"refresh", icon:"st.secondary.refresh"
        standardTile("reset", "device.switch", inactiveLabel: false, decoration: "flat") {
        				state "default", label:"reset kWh", action:"reset"
        standardTile("configure", "device.switch", inactiveLabel: false, decoration: "flat") {
        				state "default", label:"", action:"configure", icon:"st.secondary.configure"
        valueTile("power2", "device.power2", decoration: "flat") {
		valueTile("energy2", "device.energy2", decoration: "flat") {
        valueTile("power3", "device.power3", decoration: "flat") {
		valueTile("energy3", "device.energy3", decoration: "flat") {
        main(["switch1", "power", "energy"])
        details(["switch1", "power", "energy", "switch2", "power2", "energy2",
        "switch3", "power3", "energy3", "refresh", "configure", "reset"])
// 0x25 0x32 0x27 0x70 0x85 0x72 0x86 0x60 0xEF 0x82
// 0x25: switch binary
// 0x32: meter
// 0x27: switch all
// 0x70: configuration
// 0x85: association
// 0x86: version
// 0x60: multi-channel
// 0xEF: mark
// 0x82: hail
// parse events into attributes
	 log.debug "Parsing desc => '${description}'"
    def result = null
    def cmd = zwave.parse(description, [0x60:3, 0x25:1, 0x32:1, 0x70:1])
    if (cmd) {
        result = createEvent(zwaveEvent(cmd))
    log.debug "Parsing result => '${result}'"
    return result
//Reports
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
        [name: "switch", value: cmd.value ? "on" : "off", type: "physical"]
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
        [name: "switch", value: cmd.value ? "on" : "off", type: "digital"]
def zwaveEvent(physicalgraph.zwave.commands.meterv1.MeterReport cmd) {
	def map = []
	if (cmd.scale == 0) {
    	map = [ name: "energy", value: cmd.scaledMeterValue, unit: "kWh" ]
    else if (cmd.scale == 2) {
    	map = [ name: "power", value: Math.round(cmd.scaledMeterValue), unit: "W" ]
    map
def zwaveEvent(int endPoint, physicalgraph.zwave.commands.meterv1.MeterReport cmd) {
	// MeterReport(deltaTime: 1368, meterType: 1, meterValue: [0, 3, 29, 17], precision: 3, previousMeterValue: [0, 3, 29, 17], rateType: 1, reserved02: false, scale: 0, scaledMeterValue: 204.049, scaledPreviousMeterValue: 204.049, size: 4)
	 log.debug "EndPoint $endPoint, MeterReport $cmd"
    def map = []
    	map = [ name: "energy" + endPoint, value: cmd.scaledMeterValue, unit: "kWh" ]
    	map = [ name: "power" + endPoint, value: Math.round(cmd.scaledMeterValue), unit: "W" ]
    map
def zwaveEvent(physicalgraph.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
	 log.debug "MultiChannelCmdEncap $cmd"
    def map = [ name: "switch$cmd.sourceEndPoint" ]
    if (cmd.commandClass == 37){
    	if (cmd.parameter == [0]) {
        	map.value = "off"
        if (cmd.parameter == [255]) {
            map.value = "on"
        map
    else if (cmd.commandClass == 50) {
    	// bitAddress: false, command: 2, commandClass: 50, destinationEndPoint: 1, parameter: [33, 100, 0, 0, 0, 0, 0, 94, 0, 0, 0, 0], res01: false, sourceEndPoint: 1
        def hex1 = { n -> String.format("%02X", n) }
        def desc = "command: ${hex1(cmd.commandClass)}${hex1(cmd.command)}, payload: " + cmd.parameter.collect{hex1(it)}.join(" ")
        // Re-assign source end point 3-6 to 1-4 and 1-2 to 5-6 to sync up with the switch end points.
        // Source end point in the message refers to always-on sockets.
        zwaveEvent((cmd.sourceEndPoint > 3) ? (cmd.sourceEndPoint-3) : (cmd.sourceEndPoint+3), zwave.parse(desc, [ 0x60:3, 0x25:1, 0x32:1, 0x70:1 ]))
        	map.value = "off"
            map.value = "on"
        map
        zwaveEvent(cmd.sourceEndPoint, zwave.parse(desc, [ 0x60:3, 0x25:1, 0x32:1, 0x70:1 ]))
def zwaveEvent(physicalgraph.zwave.commands.multichannelv3.MultiChannelCapabilityReport cmd) {
//	  [50, 37, 32], dynamic: false, endPoint: 1, genericDeviceClass: 16, specificDeviceClass: 1)
    log.debug "multichannelv3.MultiChannelCapabilityReport $cmd"
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
	log.debug "Configuration Report for parameter ${cmd.parameterNumber}: Value is ${cmd.configurationValue}, Size is ${cmd.size}"
def zwaveEvent(physicalgraph.zwave.Command cmd) {
        // Handles all Z-Wave commands we aren't interested in
    log.debug "Capture All $cmd"
// handle commands
def refresh() {
	def cmds = []
 	for ( i in 1..3 )
    	cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:i, commandClass:37, command:2).format()
    for ( i in 1..3 ) {
        cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:i, commandClass:50, command:1, parameter:[0]).format()
        cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:i, commandClass:50, command:1, parameter:[16]).format()
    cmds << zwave.meterV2.meterGet(scale:0).format()
    cmds << zwave.meterV2.meterGet(scale:2).format()
    delayBetween(cmds)
def on(value) {
	log.debug "value $value"
	delayBetween([
		zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint: value, commandClass:37, command:1, parameter:[255]).format(),
		zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint: value, commandClass:37, command:2).format()
def off(value) {
	delayBetween([
		zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint: value, commandClass:37, command:1, parameter:[0]).format(),
def poll() {
	log.debug "Poll - Refreshing"
	refresh()
def configure() {
	log.debug "Executing 'configure'"
    delayBetween([
    	zwave.configurationV1.configurationSet(parameterNumber:101, size:4, configurationValue: [ 0, 0, 127, 127 ]).format(),	// Report meter on all channels (6 sockets + master)
        zwave.configurationV1.configurationSet(parameterNumber:111, size:4, scaledConfigurationValue: 120).format(),		// 120s interval for meter reports
        zwave.configurationV1.configurationSet(parameterNumber:4, configurationValue: [0]).format()				// Report reguarly
def on1() {
	delayBetween([
def off1() {
	delayBetween([
		zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:37, command:1, parameter:[0]).format(),
def on2() {
	delayBetween([
		zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:2, commandClass:37, command:1, parameter:[255]).format(),
		zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:2, commandClass:37, command:2).format()
def off2() {
	delayBetween([
		zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:2, commandClass:37, command:1, parameter:[0]).format(),
def on3() {
	delayBetween([
		zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:3, commandClass:37, command:1, parameter:[255]).format(),
		zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:3, commandClass:37, command:2).format()
def off3() {
	delayBetween([
		zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:3, commandClass:37, command:1, parameter:[0]).format(),
//test
def testB() {
	def cmds = []
         cmds << zwave.multiChannelV3.multiChannelCapabilityGet(endPoint:1).format()
         cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:3, commandClass:50, command:1, parameter:[0]).format()
         cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:3, commandClass:50, command:1, parameter:[16]).format()
	     cmds << zwave.multiChannelV3.multiChannelEndPointFind(genericDeviceClass:32).format()
	     cmds << zwave.multiChannelV3.multiChannelEndPointGet().format()
        cmds << zwave.configurationV1.configurationGet(parameterNumber:101).format()
        cmds << zwave.configurationV1.configurationGet(parameterNumber:4).format()
        cmds << zwave.configurationV1.configurationGet(parameterNumber:90).format()
	log.debug "Sending ${cmds.inspect()}"
	delayBetween(cmds, 2300)
def testA() {
 log.debug "testA"
 def cmds = []
// cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:50, command:1, parameter:[0]).format()
// cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:50, command:1, parameter:[16]).format()
// cmds <<		zwave.switchBinaryV1.switchBinaryGet().format()
// cmds <<		zwave.meterV2.meterGet(scale: 0).format()
cmds <<	zwave.meterV3.meterGet(scale: 0).format()
log.debug "$cmds"
delayBetween(cmds, 1000)
//reset
def reset() {
	def cmds = []
    cmds << zwave.meterV2.meterReset().format()
    for ( i in 1..6 )
	delayBetween(cmds)
