Here it is; it also automatically sets the clock (you’ll need to change the timezone in the code if you are not eastern time; I was too lazy to make it a parameter):
metadata {
// Automatically generated. Make future change here.
definition (name: "Z-Wave thermostat with battery level", author: "minollo") {
capability "Relative Humidity Measurement"
capability "Battery"
capability "Temperature Measurement"
capability "Thermostat"
capability "Polling"
command "poll"
// simulator metadata
simulator {
status "off" : "command: 4003, payload: 00"
status "heat" : "command: 4003, payload: 01"
status "cool" : "command: 4003, payload: 02"
status "auto" : "command: 4003, payload: 03"
status "emergencyHeat" : "command: 4003, payload: 04"
status "fanAuto" : "command: 4403, payload: 00"
status "fanOn" : "command: 4403, payload: 01"
status "fanCirculate" : "command: 4403, payload: 06"
status "heat 60" : "command: 4303, payload: 01 01 3C"
status "heat 68" : "command: 4303, payload: 01 01 44"
status "heat 72" : "command: 4303, payload: 01 01 48"
status "cool 72" : "command: 4303, payload: 02 01 48"
status "cool 76" : "command: 4303, payload: 02 01 4C"
status "cool 80" : "command: 4303, payload: 02 01 50"
status "temp 58" : "command: 3105, payload: 01 22 02 44"
status "temp 62" : "command: 3105, payload: 01 22 02 6C"
status "temp 70" : "command: 3105, payload: 01 22 02 BC"
status "temp 74" : "command: 3105, payload: 01 22 02 E4"
status "temp 78" : "command: 3105, payload: 01 22 03 0C"
status "temp 82" : "command: 3105, payload: 01 22 03 34"
status "idle" : "command: 4203, payload: 00"
status "heating" : "command: 4203, payload: 01"
status "cooling" : "command: 4203, payload: 02"
status "fan only" : "command: 4203, payload: 03"
status "pending heat" : "command: 4203, payload: 04"
status "pending cool" : "command: 4203, payload: 05"
status "vent economizer": "command: 4203, payload: 06"
// reply messages
reply "2502": "command: 2503, payload: FF"
tiles {
valueTile("temperature", "device.temperature", width: 2, height: 2) {
state("temperature", label:'${currentValue}°', unit:"F",
backgroundColors:[
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
standardTile("mode", "device.thermostatMode", inactiveLabel: false, decoration: "flat") {
state "off", label:'${name}', action:"switchMode"
state "heat", label:'${name}', action:"switchMode"
state "emergencyHeat", label:'${name}', action:"switchMode"
state "cool", label:'${name}', action:"switchMode"
state "auto", label:'${name}', action:"switchMode"
standardTile("fanMode", "device.thermostatFanMode", inactiveLabel: false, decoration: "flat") {
state "fanAuto", label:'${name}', action:"switchFanMode"
state "fanOn", label:'${name}', action:"switchFanMode"
state "fanCirculate", label:'${name}', action:"switchFanMode"
controlTile("heatSliderControl", "device.heatingSetpoint", "slider", height: 1, width: 2, inactiveLabel: false) {
state "setHeatingSetpoint", action:"thermostat.setHeatingSetpoint", backgroundColor:"#d04e00"
valueTile("heatingSetpoint", "device.heatingSetpoint", inactiveLabel: false, decoration: "flat") {
state "heat", label:'${currentValue}° heat', unit:"F", backgroundColor:"#ffffff"
controlTile("coolSliderControl", "device.coolingSetpoint", "slider", height: 1, width: 2, inactiveLabel: false) {
state "setCoolingSetpoint", action:"thermostat.setCoolingSetpoint", backgroundColor: "#1e9cbb"
valueTile("coolingSetpoint", "device.coolingSetpoint", inactiveLabel: false, decoration: "flat") {
state "cool", label:'${currentValue}° cool', unit:"F", backgroundColor:"#ffffff"
standardTile("refresh", "device.thermostatMode", inactiveLabel: false, decoration: "flat") {
state "default", action:"polling.poll", icon:"st.secondary.refresh"
standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat") {
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
main "temperature"
details(["temperature", "mode", "fanMode", "heatSliderControl", "heatingSetpoint", "coolSliderControl", "coolingSetpoint", "refresh", "configure"])
def parse(String description)
def map = createEvent(zwaveEvent(zwave.parse(description, [0x42:1, 0x43:2, 0x31:3, 0x80:1])))
if (!map) {
return null
def result = [map]
if (map.isStateChange && map.name in ["heatingSetpoint","coolingSetpoint","thermostatMode"]) {
def map2 = [
unit: "F"
if (map.name == "thermostatMode") {
updateState("lastTriedMode", map.value)
if (map.value == "cool") {
map2.value = device.latestValue("coolingSetpoint")
log.info "THERMOSTAT, latest cooling setpoint = ${map2.value}"
else {
map2.value = device.latestValue("heatingSetpoint")
log.info "THERMOSTAT, latest heating setpoint = ${map2.value}"
else {
def mode = device.latestValue("thermostatMode")
log.info "THERMOSTAT, latest mode = ${mode}"
if ((map.name == "heatingSetpoint" && mode == "heat") || (map.name == "coolingSetpoint" && mode == "cool")) {
map2.value = map.value
map2.unit = map.unit
if (map2.value != null) {
log.debug "THERMOSTAT, adding setpoint event: $map"
result << createEvent(map2)
} else if (map.name == "thermostatFanMode" && map.isStateChange) {
updateState("lastTriedFanMode", map.value)
log.debug "ParseEx returned $result"
result
// Event Generation
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
def nowTime = new Date().time
state.lastBatteryGet = nowTime
def map = [ name: "battery", unit: "%" ]
if (cmd.batteryLevel == 0xFF || cmd.batteryLevel == 0) {
map.value = 1
map.descriptionText = "$device.displayName battery is low!"
} else {
map.value = cmd.batteryLevel
map
def zwaveEvent(physicalgraph.zwave.commands.thermostatsetpointv2.ThermostatSetpointReport cmd)
def map = [:]
map.value = cmd.scaledValue.toString()
map.unit = cmd.scale == 1 ? "F" : "C"
map.displayed = false
switch (cmd.setpointType) {
case 1:
map.name = "heatingSetpoint"
break;
case 2:
map.name = "coolingSetpoint"
break;
default:
return [:]
// So we can respond with same format
state.size = cmd.size
state.scale = cmd.scale
state.precision = cmd.precision
map
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv3.SensorMultilevelReport cmd)
log.debug "SensorMultilevelReport ${cmd}"
def map = [:]
switch (cmd.sensorType) {
case 1:
// temperature
map.value = cmd.scaledSensorValue.toString()
map.name = "temperature"
break;
case 5:
// humidity
map.value = cmd.scaledSensorValue.toInteger().toString()
map.unit = "%"
map.name = "humidity"
break;
map
def zwaveEvent(physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport cmd)
def map = [:]
switch (cmd.operatingState) {
case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_IDLE:
map.value = "idle"
break
case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_HEATING:
map.value = "heating"
break
case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_COOLING:
map.value = "cooling"
break
case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_FAN_ONLY:
map.value = "fan only"
break
case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_PENDING_HEAT:
map.value = "pending heat"
break
case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_PENDING_COOL:
map.value = "pending cool"
break
case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_VENT_ECONOMIZER:
map.value = "vent economizer"
break
map.name = "thermostatOperatingState"
map
def zwaveEvent(physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport cmd) {
def map = [:]
switch (cmd.mode) {
case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_OFF:
map.value = "off"
break
case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_HEAT:
map.value = "heat"
break
case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_AUXILIARY_HEAT:
map.value = "emergencyHeat"
break
case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_COOL:
map.value = "cool"
break
case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_AUTO:
map.value = "auto"
break
map.name = "thermostatMode"
map
def zwaveEvent(physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport cmd) {
def map = [:]
switch (cmd.fanMode) {
case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_AUTO_LOW:
map.value = "fanAuto"
break
case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_LOW:
map.value = "fanOn"
break
case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_CIRCULATION:
map.value = "fanCirculate"
break
map.name = "thermostatFanMode"
map
def zwaveEvent(physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeSupportedReport cmd) {
def supportedModes = ""
if(cmd.off) { supportedModes += "off " }
if(cmd.heat) { supportedModes += "heat " }
if(cmd.auxiliaryemergencyHeat) { supportedModes += "emergencyHeat " }
if(cmd.cool) { supportedModes += "cool " }
if(cmd.auto) { supportedModes += "auto " }
updateState("supportedModes", supportedModes)
def zwaveEvent(physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeSupportedReport cmd) {
def supportedFanModes = ""
if(cmd.auto) { supportedFanModes += "fanAuto " }
if(cmd.low) { supportedFanModes += "fanOn " }
if(cmd.circulation) { supportedFanModes += "fanCirculate " }
updateState("supportedFanModes", supportedFanModes)
def updateState(String name, String value) {
state[name] = value
device.updateDataValue(name, value)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
log.debug "Zwave event received: $cmd"
log.warn "Unexpected zwave command $cmd"
// Command Implementations
def poll() {
delayBetween([
zwave.sensorMultilevelV3.sensorMultilevelGet().format(), // current temperature
zwave.thermostatSetpointV1.thermostatSetpointGet(setpointType: 1).format(),
zwave.thermostatSetpointV1.thermostatSetpointGet(setpointType: 2).format(),
zwave.thermostatModeV2.thermostatModeGet().format(),
zwave.thermostatFanModeV3.thermostatFanModeGet().format(),
zwave.thermostatOperatingStateV1.thermostatOperatingStateGet().format(),
getBattery(),
setClock()
], 2300)
private getBattery() { //once every 10 hours
def ageInMinutes = state.lastBatteryGet ? (nowTime - state.lastBatteryGet)/60000 : 600
log.debug "Battery report age: ${ageInMinutes} minutes"
if (ageInMinutes >= 600) {
log.debug "Fetching fresh battery value"
zwave.batteryV1.batteryGet().format()
} else "delay 87"
private setClock() { //once a day
def ageInMinutes = state.lastClockSet ? (nowTime - state.lastClockSet)/60000 : 1440
log.debug "Clock set age: ${ageInMinutes} minutes"
if (ageInMinutes >= 1440) {
log.debug "Setting clock"
state.lastClockSet = nowTime
def nowCal = Calendar.getInstance(TimeZone.getTimeZone("America/New_York"));
zwave.clockV1.clockSet(hour: nowCal.get(Calendar.HOUR_OF_DAY), minute: nowCal.get(Calendar.MINUTE), weekday: nowCal.get(Calendar.DAY_OF_WEEK)).format()
} else "delay 87"
def setHeatingSetpoint(degreesF) {
setHeatingSetpoint(degreesF.toDouble())
def setHeatingSetpoint(Double degreesF) {
def p = (state.precision == null) ? 1 : state.precision
delayBetween([
zwave.thermostatSetpointV1.thermostatSetpointSet(setpointType: 1, scale: 1, precision: p, scaledValue: degreesF).format(),
def setCoolingSetpoint(degreesF) {
setCoolingSetpoint(degreesF.toDouble())
def setCoolingSetpoint(Double degreesF) {
delayBetween([
zwave.thermostatSetpointV1.thermostatSetpointSet(setpointType: 2, scale: 1, precision: p, scaledValue: degreesF).format(),
def configure() {
delayBetween([
zwave.thermostatModeV2.thermostatModeSupportedGet().format(),
zwave.thermostatFanModeV3.thermostatFanModeSupportedGet().format(),
zwave.associationV1.associationSet(groupingIdentifier:1, nodeId:[zwaveHubNodeId]).format()
], 2300)
def modes() {
["off", "auto", "emergencyHeat", "heat", "cool"]
def switchMode() {
def currentMode = device.currentState("thermostatMode")?.value
def lastTriedMode = getDataByName("lastTriedMode") ?: currentMode ?: "off"
def supportedModes = getDataByName("supportedModes")
def modeOrder = modes()
def next = { modeOrder[modeOrder.indexOf(it) + 1] ?: modeOrder[0] }
def nextMode = next(lastTriedMode)
if (supportedModes?.contains(currentMode)) {
while (!supportedModes.contains(nextMode) && nextMode != "off") {
nextMode = next(nextMode)
switchToMode(nextMode)
def switchToMode(nextMode) {
if(supportedModes && !supportedModes.contains(nextMode)) log.warn "thermostat mode '$nextMode' is not supported"
if (nextMode in modes()) {
updateState("lastTriedMode", nextMode)
return "$nextMode"()
} else {
log.debug("no mode method '$nextMode'")
def switchFanMode() {
def currentMode = device.currentState("thermostatFanMode")?.value
def lastTriedMode = getDataByName("lastTriedFanMode") ?: currentMode ?: "off"
def supportedModes = getDataByName("supportedFanModes") ?: "fanAuto fanOn"
def modeOrder = ["fanAuto", "fanCirculate", "fanOn"]
while (!supportedModes?.contains(nextMode) && nextMode != "fanAuto") {
switchToFanMode(nextMode)
def switchToFanMode(nextMode) {
def supportedFanModes = getDataByName("supportedFanModes")
if(supportedFanModes && !supportedFanModes.contains(nextMode)) log.warn "thermostat mode '$nextMode' is not supported"
def returnCommand
if (nextMode == "fanAuto") {
returnCommand = fanAuto()
} else if (nextMode == "fanOn") {
returnCommand = fanOn()
} else if (nextMode == "fanCirculate") {
returnCommand = fanCirculate()
} else {
log.debug("no fan mode '$nextMode'")
if(returnCommand) updateState("lastTriedFanMode", nextMode)
returnCommand
def getDataByName(String name) {
state[name] ?: device.getDataValue(name)
def getModeMap() { [
"off": 0,
"heat": 1,
"cool": 2,
"emergency heat": 4
def setThermostatMode(String value) {
delayBetween([
zwave.thermostatModeV2.thermostatModeSet(mode: modeMap[value]).format(),
def getFanModeMap() { [
"auto": 0,
"on": 1,
"circulate": 6
def setThermostatFanMode(String value) {
delayBetween([
zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: fanModeMap[value]).format(),
def off() {
delayBetween([
zwave.thermostatModeV2.thermostatModeSet(mode: 0).format(),
def heat() {
delayBetween([
zwave.thermostatModeV2.thermostatModeSet(mode: 1).format(),
def emergencyHeat() {
delayBetween([
zwave.thermostatModeV2.thermostatModeSet(mode: 4).format(),
def cool() {
delayBetween([
zwave.thermostatModeV2.thermostatModeSet(mode: 2).format(),
def auto() {
delayBetween([
zwave.thermostatModeV2.thermostatModeSet(mode: 3).format(),
def fanOn() {
delayBetween([
zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 1).format(),
def fanAuto() {
delayBetween([
zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 0).format(),
def fanCirculate() {
delayBetween([
zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 6).format(),
