This is the change i made for the get request, ONLY to the device type so the take method would work.
* Foscam - FI8910W
* Author: danny@smartthings.com
* Author: brian@bevey.org
* Author: morgan@jedifan.com
* Date: 01/29/2014
* Modified this to work with FI8910W
* Modified example Foscam device type to support dynamic input of credentials
* and enable / disable motion alarm to easily integrate into homemade
* security systems (when away, mark "alarmStatus" as "on", when present, mark
* "alarmStatus" as "off". For use with email or FTP image uploading built
* into Foscam cameras.
* Capability: Image Capture, Polling
* Custom Attributes: setStatus, alarmStatus
* Custom Commands: alarmOn, alarmOff, toggleAlarm, left, right, up, down,
* pause, set, preset, preset1, preset2, preset3
preferences {
input("username", "text", title: "Username", description: "Your Foscam username")
input("password", "password", title: "Password", description: "Your Foscam password")
input("ip", "text", title: "IP address", description: "The IP address of your Foscam")
input("port", "text", title: "Port", description: "The port of your Foscam")
// for the UI
metadata {
tiles {
carouselTile("cameraDetails", "device.image", width: 3, height: 2) { }
standardTile("camera", "device.image", width: 1, height: 1, canChangeIcon: false, inactiveLabel: true, canChangeBackground: false) {
state "default", label: "", action: "Image Capture.take", icon: "st.camera.dropcam-centered", backgroundColor: "#FFFFFF"
standardTile("take", "device.image", width: 1, height: 1, canChangeIcon: false, inactiveLabel: true, canChangeBackground: false, decoration: "flat") {
state "take", label: "", action: "Image Capture.take", icon: "st.secondary.take", nextState:"taking"
standardTile("up", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") {
state "take", label: "up", action: "up", icon: ""
standardTile("alarmStatus", "device.alarmStatus", width: 1, height: 1, canChangeIcon: false, inactiveLabel: true, canChangeBackground: false) {
state "off", label: "off", action: "toggleAlarm", icon: "st.camera.dropcam-centered", backgroundColor: "#FFFFFF"
state "on", label: "on", action: "toggleAlarm", icon: "st.camera.dropcam-centered", backgroundColor: "#53A7C0"
standardTile("left", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") {
state "take", label: "left", action: "left", icon: ""
standardTile("pause", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") {
state "pause", label: "pause", action: "pause", icon: ""
standardTile("right", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") {
state "take", label: "right", action: "right", icon: ""
standardTile("blank", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") {
state "pause", label: "", action: "pause", icon: ""
standardTile("down", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") {
state "down", label: "down", action: "down", icon: ""
standardTile("set", "device.setStatus", width: 1, height: 1, canChangeIcon: false, inactiveLabel: true, canChangeBackground: false) {
state "set", label: "set", action: "set", icon: "", backgroundColor: "#FFFFFF"
state "setting", label: "set mode", action: "set", icon: "", backgroundColor: "#53A7C0"
standardTile("preset1", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") {
state "preset1", label: "preset 1", action: "preset1", icon: ""
standardTile("preset2", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") {
state "preset2", label: "preset 2", action: "preset2", icon: ""
standardTile("preset3", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") {
state "preset3", label: "preset 3", action: "preset3", icon: ""
standardTile("refresh", "device.alarmStatus", inactiveLabel: false, decoration: "flat") {
state "default", action:"polling.poll", icon:"st.secondary.refresh"
main "alarmStatus"
details(["cameraDetails", "take", "up", "alarmStatus", "left", "pause", "right", "blank", "down", "set", "preset1", "preset2", "preset3", "refresh"])
def parseCameraResponse(def response) {
if(response.headers.'Content-Type'.contains("image/jpeg")) {
def imageBytes = response.data
if(imageBytes) {
storeImage(getPictureName(), imageBytes)
private getPictureName() {
def pictureUuid = java.util.UUID.randomUUID().toString().replaceAll('-', '')
"image" + "_$pictureUuid" + ".jpg"
private take() {
log.debug("Take a photo")
httpGet("http://${settings.ip}:${settings.port}/snapshot.cgi?user=${settings.username}&pwd=${settings.password}&resolution=32&rate=0") {response ->
log.debug("Image captured")
parseCameraResponse(response)
def toggleAlarm() {
if(device.currentValue("alarmStatus") == "on") {
alarmOff()
else {
alarmOn()
private alarmOn() {
api("set_alarm", "motion_armed=1") {
log.debug("Alarm changed to: on")
sendEvent(name: "alarmStatus", value: "on");
private alarmOff() {
api("set_alarm", "motion_armed=0") {
log.debug("Alarm changed to: off")
sendEvent(name: "alarmStatus", value: "off");
def left() {
api("decoder_control", "command=6") {
log.debug("Executing 'left'")
def right() {
api("decoder_control", "command=4") {
log.debug("Executing 'right'")
def up() {
api("decoder_control", "command=0") {
log.debug("Executing 'up'")
def down() {
api("decoder_control", "command=2") {
log.debug("Executing 'down'")
def pause() {
api("decoder_control", "command=1") {}
def preset1() {
preset(1)
def preset2() {
preset(2)
def preset3() {
preset(3)
//go to a preset location
def preset(def num) {
if(num == null) return
if(device.currentValue("setStatus") == "setting") {
setPreset(num)
else {
log.debug("Go To Preset Location")
//1 is 31, 2 is 33, 3 is 35
def cmd = 30 + (num * 2) - 1
api("decoder_control", "command=${cmd}") {}
//set the preset number to the current location
def setPreset(def num) {
log.debug("Set Preset")
//1 is 30, 2 is 32, 3 is 34... 8 is 44
int cmd = 28 + (num * 2)
sendCmd(cmd)
log.debug("Exit Set Mode")
sendEvent(name: "setStatus", value: "set");
//toggle the the mode to set the preset
def set() {
if(device.currentValue("setStatus") == "set") {
log.debug("Entering Set Mode")
sendEvent(name: "setStatus", value: "setting");
else {
def api(method, args = [], success = {}) {
def methods = [
"decoder_control": [uri: "http://${ip}:${port}/decoder_control.cgi${login()}&${args}", type: "post"],
"snapshot": [uri: "http://${ip}:${port}/snapshot.cgi${login()}&${args}", type: "post"],
"set_alarm": [uri: "http://${ip}:${port}/set_alarm.cgi${login()}&${args}", type: "post"],
"reboot": [uri: "http://${ip}:${port}/reboot.cgi${login()}&${args}", type: "post"],
"camera_control": [uri: "http://${ip}:${port}/camera_control.cgi${login()}&${args}", type: "post"],
"get_params": [uri: "http://${ip}:${port}/get_params.cgi${login()}", type: "get"],
"videostream": [uri: "http://${ip}:${port}/videostream.cgi${login()}", type: "get"]
def request = methods.getAt(method)
doRequest(request.uri, request.type, success)
private doRequest(uri, type, success) {
log.debug(uri)
if(type == "post") {
httpPost(uri , "", success)
else if(type == "get") {
httpGet(uri, success)
private login() {
return "?user=${username}&pwd=${password}"
def poll() {
api("get_params", []) {
def params = ""
it.data.eachLine {
if(it.startsWith("var alarm_motion_armed=0")) {
log.info("Polled: Alarm off")
if(it.startsWith("var alarm_motion_armed=1")) {
log.info("Polled: Alarm on")
